Steve Woodhouse
- Aug 11, 2023
Fair enough but a lot of people that use Folder View in LMS do so because they can't be bothered to tag files properlyI think I've been absolutely 100% clear all along that all my music is tagged, and that I search using those on the odd occasion it's necessary.
It doesn't take 14 minutes when searching in the WiiM Home app. He isn't searching in Windows.Wait 14 minutes to find "best of" yeah brilliant.
You're using indexing, via database, and not folder search.
Cope harder.
Cope harder.
Fair enough but a lot of people that use Folder View in LMS do so because they can't be bothered to tag files properly![]()
Depends if the storage is local USB, or over the network, if it's scanned into database in wiim then it indexes right?
I'm talking of un-indexed, browse by folder, over a network, not scanned - as that is could be cached/indexed folder search. You should notice this as will have a audible HD access on every change. But with database it'll just read through the single optimised database file, like using spreadhseet it'll find it instantly and can it to search any tag, something browse by folder cannot do.
I've used rockboxed players, it has a database system but you can also browse by folder.
And in LMS you can browse by folder, which is slower there is a delay everytime you go by directory- on a older NAS, compared to the same NAS where the database was still instant.
Exactly. Some find too much effort tag files, so just use "as is"
Within LMS can use search variables, he can say "waaaah I don't want to use that, so it's naff" just making lame excuses and being a troll.
Just ignore him.
That sounds just like you.just making lame excuses and being a troll.
Just ignore him.
hahaha. So you ARE using a database/indexing.
ROFL
ROFL
WMP? ROFL Terrible piece of software
Get out of here.
Just curious, what other means are there to control a WiiM device beside using the WiiM Home app? And the remote of course? I wasn't aware of another means.The beauty of the WiiM products is that you don't need to to use the WiiM app to control your music. Unless I want to play from Amazon Music I would never use the WiiM app to play music.
Depends what you want to play, whether you have Ios or Android, and other things.Just curious, what other means are there to control a WiiM device beside using the WiiM Home app? And the remote of course? I wasn't aware of another means.
That's very interesting. I had no idea. So you're playing through the WiiM device's Wi-Fi then? I will have to give all that a look. I'm running a DLNA server on a Raspberry Pi.Depends what you want to play, whether you have Ios or Android, and other things.
e.g. I usually use tidal connect rather than tidal from within the wiim app, and being on Android I use the bubbleupnp app for my local (nas) music.
Someitimes bubble for tidal too. Bubble also has qobuz, but I don't
Others use LMS (Lyrion Music Server iirc) to play music from BBC radio, tidal, qobuz, local files and more. LMS is usually installed on a pc, nas or raspberry pi.
Similar to bubble is Mconnect, on both Ios and Android. There are others too.
Given you're on Android you should take a look at Symfonium.That's very interesting. I had no idea. So you're playing through the WiiM device's Wi-Fi then? I will have to give all that a look. I'm running a DLNA server on a Raspberry Pi.
