Change power cord to the Ultra
How can that be?
I see no logic in these claims about power cables. I am still waiting to see a good explanation and not just feelings.
Power cords can make an audible difference and it seems that's due to filtering of injected/induced RFI/EMI. The issue may depend on locality (mains RFI noise) and interference from nearby RFI/EMI sources. Not every case benefits from a filtered cord, others do. I have none, but I do have a competent power line conditioner.
Edit: typo.
Power cords can make an audible difference and it seems that's due to filtering of injected/induced RFI/EMI. The issue may depend on locality (mains RFI noise) and intereference from nearby RFI/EMI sources. Not every case benefits from a filtered cord, others do. I have none, but I do have a competent power line conditioner.
Yes. If you have a lot of noise and badly designed analog circuits and power supplies you may get audibly noise from the environment added to the analog signal. That was the case 50 years ago, not so much nowadays.
For digital audio it cannot change anything except if it is so bad as it alters the bits and in that case the CPU will also fail.
IYO (In Your Opinion)… :) And… it is not audible noise… it’s intermodulation effects.
I was just shuffling around my listening setup and found the power cable supplied with the Ultra a bit too long for my needs.
I stumbled upon a nice looking (judging by the renders) braided cable.
It's €13 for the 1m version on Amazon so I'm afraid it doesn't have golden, interwoven conductors or something like that. Just a bit nicer looking ;)
I bought the 2 m version of this very same cable because the original was just a tiny bit short for my Amp Pro.
And yes, it looks nice. :)
It was the last thing I upgraded in my system after power condition, dac, ddc etc. I think it is a shame how people dismiss cables without hearing them first. Just send it back if you can't hear a difference..
Because what you suggest is called confirmation bias.
It won't and can't make any audible difference.
Unfortunately there is snake oil in this industry and it pisses me off, going into the hifi shows and I see a £1000 audiophile network switch.
