I have a test unit I'm busy playing around with.
I've come across an issue I feel needs fixing urgently, the Coaxial input is recessed to far into the unit and there isnt enough space around the input to use certain Coaxial cables, the Barrel on the RCA connectors is to big to fit over the input, I've tried a Van Den Hul and QED cable and both only fit on halfway.
My thinking is that a lot of people will be purchasing this unit for the Coaxial Output as its generally the preferred connection over optical for those using it with a Dac.
Is it to late to fix the gap between the connector and casing?
Upvote
