Crossover settings with Amp Ultra, KEF Concertos and SVS SB-2000 PRO
Havok
This is my first system with a sub. It is a stereo setup for 50% movies and 50% music. Lots of different suggestion on the web.
I have the WIIM controlling the sub. Level -5 dB, crossover 70Hz, phase 0, Subwoofer Bypass is off and main speakers output bass is off. My room is about 24' x 28' x 9. I find myself constantly changing the sub level for music vs movies and even different songs. What are good 'set it and forget it' settings? Thanks in advance!
Hi
Once set, the subwoofer level should not be changed (my opinion). Applying different EQ to TV input and music (Wi-Fi?) eliminates the need for manual adjustments.
If you wish to use different EQ for the same input, I recommend using presets.
