steadyshot
- Mar 14, 2023
I was expecting this commentNice chassis color indeed.
Well... but I'm glad it makes so extreme improvementI was expecting this comment![]()
Thanks. I hope one day they come up with a correlation of measurement data and audibility degree thresholds!Well... but I'm glad it makes so extreme improvement![]()
They are known in general. You can verify some thresholds yourself here:Thanks. I hope one day they come up with a correlation of measurement data and audibility degree thresholds!
The test was done with my 5 year old iPhone. In the beginning I did not do a comparison . So I have to do it again .They are known in general. You can verify some thresholds yourself here:
Listening Test
www.klippel.de
ToslinkOver the toslink output, right? Or even the analog one?
It seems I own …The Mini is fully transparent over its toslink output with any of my bit-perfect capable devices regardless of the charger used. And within the measurement deviation error when ASRC is used. Even the ultra low noise Allo Nirvana does change nothing here.
Maybe there are DACs which can be affected by the charger used to power the Mini, but I do not own such low quality equipment.
Not always, remember the deeply flawed review and measurements of the Sonore microRendu?You’ll get facts and measurements based objective reviews on ASR.
Definite circle jerk.And btw...the Kindergarten ASR is since a while only a place for measurement onanism for mostly first semester students.
NonsenseNot always, remember the deeply flawed review and measurements of the Sonore microRendu?
While there has been revisionist history applied there to cover up the original botch job, that review concluded the mR could not be recommended because it was not bitperfect, and caused an 8dB rise at the analog output of the USB connected DAC.
All of that was of course completely false/inaccurate, said a lot about the competency of the reviewer, and also revealed an obvious agenda/axe to grind, as well as a failure to listen to the mR at all, as an 8dB rise surely would be easily/clearly audible to the most casual observer.
Also false was Amir's assertion that the iFi iPower was the "included" power supply with the microRendu, when in fact it was just one of several options offered by Sonore, who sold that unit by default sans PSU. Once corrected on that misrepresentation, he then tried to call the iPower Sonore's "recommended" PSU, which was also false, then tried to shift the goalposts entirely by turning the whole embarrassing debacle thing into a scathing indictment of the iPower itself.
Wow was there egg all over Amir's face when it was determined his test setup was deeply flawed, including Windows Media Player (really?), with the dithered software volume control enabled. No thats not bitperfect, not through the microRendu nor any other network endpoint either.
Microsoft, Windows Media Player, buying then immediately retiring HDCD... not exactly the stuff of audio legends there.
How about the steadfast backing of that complete crock of BS known as Master Quality Adulterated? Almost caused a mutiny among the faithful over there, didn't it?
ASR = groupthink extraordinaire, which is too bad because there are various good/knowledgable people posting there.
if it is a story of jitter at the output of the mini which will be improved.. it is however easy to measure and check...Well anyway . I don’t pretend to be an authority when my background is in finance and not in sound engineering/ electrical engineering. My guess is that cleaner current feeds the clock and the optical converter in optical out therefore jitter is reduced . I did back and forth with the Apple charger . I mean you don’t even have to try to hear the big difference
Hasn’t this old canard (pun intended) been gone over before ad nauseum - jitter doesn’t really matter on the WiiM’s digital outputs and even if it did, it’s more than handled by any competent external DAC?if it is a story of jitter at the output of the mini which will be improved.. it is however easy to measure and check...
At least 4 cases for different chargers scenarios:Well anyway . I don’t pretend to be an authority when my background is in finance and not in sound engineering/ electrical engineering. My guess is that cleaner current feeds the clock and the optical converter in optical out therefore jitter is reduced . I did back and forth with the Apple charger . I mean you don’t even have to try to hear the big difference
