You will have to ask that to WiiM. What I know is that it is some new version now called Google Cast 2.0 or CastLite.Why this chromecast is different from other wiim? Is this a better version?
Do you mean just pro or pro plus??. I own a pro plus and it sounds open and beliavable through rca output, but it is obvious that it will depend of fundamental things like your speakers and your amp. GreetingsThe dac on pro using its analog wasn’t sound good. Lack the precision and finesse. It would be nice if wiim just release a straight streamer with just optical, coax and usb out. Why? Many of us own dac and prefer to use our own.
I stated pro. The pro plus has improved dac.Do you mean just pro or pro plus??. I own a pro plus and it sounds open, real through rca output, but it is obvious that it depends of fundamental things, your speakers and your amp.
I know your question is pro vs pro plus, but this is what wiim said about ultra compared to pro plus.I use a separate 3rd party DAC. Can anyone confirm that the streamer portion of the Pro and the Pro+ are the same or is there a better streamer in one of the models?
Ultra DAC souns pretty good to me, better then the Node but slightly worse then any Cambridge streamers.
However, I still prefer my external DAC sound
Yeah. Now all that's missing is the proof it isn't.In my opinion the clock inside the ultra should be at least on par with this smsl po100pro device
"External reclocker"? Jeeeeez...
Why do you think that WiiM clock is worse?In my opinion the clock inside the ultra should be at least on par with this smsl po100pro device
It’s nitpicking, but in the context of the video and the entire post, the insinuation is that it isn’t on par. But I’m sure he’ll elucidate…I don't think he was saying he thought it was worse ....
In other words at least as good.
My understanding is that he thinks that WiiM clock is not as good as PO100Pro clock. It should be at least on par, but it is not.I don't think he was saying he thought it was worse ....
You should be my English to English translatorIt’s nitpicking, but in the context of the video and the entire post, the insinuation is that it isn’t on par. But I’m sure he’ll elucidate…
The reviewer in the video suggests that it gets a cleaner sound from using the usb to spdif converter than using straight the spdif outs to his dac. The reviewer in general is supportive of wiim. The device used is cheap (smsl). I do not see any devious motive on behalf of the reviewer to claim this. Therefore if he bothered posting a video claiming that the digital output using this thing is perceptibly cleaner it is an indication that the 60usd device may have a better quality clock. Otherwise the reclocking would have introduced negative or neutral effects to the sound.Why do you think that WiiM clock is worse?
"neutral effects" is a bit self-contradictoryThe reviewer in the video suggests that it gets a cleaner sound from using the usb to spdif converter than using straight the spdif outs to his dac. The reviewer in general is supportive of wiim. The device used is cheap (smsl). I do not see any devious motive on behalf of the reviewer to claim this. Therefore if he bothered posting a video claiming that the digital output using this thing is perceptibly cleaner it is an indication that the 60usd device may have a better quality clock. Otherwise the reclocking would have introduced negative or neutral effects to the sound.
