Steve Woodhouse
- Aug 11, 2023
Okay, I’ve had the Ultra for a little under three weeks, and I wanted to give a few first impressions.
PART I
Right from the start, the packing, presentation, form factor are all top notch. A bit strange that there are no batteries with the remote, which almost everyone will use, whilst there’s an HDMI cable, which a significant number won’t use. Especially as your typical Blu-ray Disc player will come with batteries for the remote but no HDMI cable, despite it being impossible to use without the latter.
Just a little quirk, I suppose, but I want to be open, honest, and even-handed.
Connectivity is great. All the connectors feel very solid. I don’t use the volume pot at all, but I’ve tried it as some have said it’s felt cheap/funny, but I didn’t get that. Anyone having issues, I’d have a look at what Erin said in his review, see if that helps.
Functionality, is user-friendly, it’s as easy as the WiiM Mini.
Sound quality: initially I’d just say it appears to sound as it should, but more later.
What’s immediately marvellous is the subwoofer integration. As smooth as a Brazilian’s…erm…Brazilian.
So, all set up and ready to go, but then a bit of a brick wall. Unable to complete room correction and set sub levels due to domestic considerations, and an unusual lack of updates from WiiM as to what was happening with the sub being integrated into room correction.
But it’s here now, so off we go.
PART I
