You would be connecting a CD transport then, not a CD player.If I were to connect a CD player I’d connect it to the optical input.
Depends on how you connect it.So what Is my Nad C538, a cd player or cd transport?
Please keep comments courteous as per the forum rules. ThanksIf you were serious about your (questionable) argument you would have issued a feature request by now, as suggested before.
Instead, you're wasting your time discussing pointless stuff with fellow WiiM users so far. It's all up to you.![]()
Well perhaps they could take a leaf out of Isaac Newton’s book and potentially see further by standing on the shoulders of giantsyou are faced with a new, very mainstream brand which is discovering audio step by step...
you shouldn't expect too much or think about comparisons with audio brands present since the 60s and 70s etc
I think they’ve hit the ground running and have understood the needs of the audio market well and are taking it by storm.you are faced with a new, very mainstream brand which is discovering audio step by step...
Part of the problem with using line level input devices with a phono preamp is that there aren't any standards for the output level of the cartridges. Between MC and MM and high output and low output, there's too much variety to have a standard. It seems like finding a good combination may take some investigation and being able to demo a pre before committing. Looking for optimal playback quality with vinyl has never really been plug and play. Using a line level input device with gain cranked to max is likely to create more distortion than desired.Anyway, the point I’m try to get to is that the analogue line input of the Wiim amp is just as likely to be used for turntables as CD players. As most CD players are also CD transports (and not many are just players ie lacking any digital output) and have digital outputs then there are two options available to connect a cd player/transport but only one for a turntable. Hence it is not unreasonable to suggest that the analogue line input could be better matched for connection to a turntable pre amp . After all many HiFi aficionados also like to play vinyl; cd players can be connected digitally, streaming is taken care of by the amp itself and NAS devices by the usb input.
