AdieH
Hi all,
Cheers,
Adrian
It would and I have contacted Topping but I see similar complaints on this thread. Same issue which, in my case I guess gets amplified when using XLR.
Reading some posts above the noise is related to shutting off and turning on the clocks which is on the Wiim.
Do you have any other source with digital output you could try into the Dac instead of the WiiM to see what happens,
No noise with any of my 4 transports. Now, those are fixed sampling rate whereas the Wiim changes according to the source track.
Wiim sent me a firmware update to try. Great response from Wiim!!!!
Hi wunderkind, Team
We're excited to announce that a firmware fix for Line out on WiiM Mini/Pro is currently undergoing thorough internal testing. For those who have the DAC that can't handle changing sample rate well from their optical or coax input, we provide the fixed frame rate option with a good ASRC.
If you're interested in being an early adopter as one of our Beta users, we'd love to have your involvement. Please provide your ticket number, and I will coordinate with our team to authorize a Beta version specifically for your device.
Participating as a Beta user offers you the opportunity to experience improvements firsthand and provide valuable feedback that can shape the final release. If you prefer to wait for the official update, rest assured, we are on track to release this fix in our public firmware by the end of January. Your choice and support in this process are greatly appreciated.
I have this clicking problem with my smsl su-1 dac, but fixed bitrate still is not available. should i make a ticket to access it?
i dont think so
Sorry, I never owned a Mini, and there was talk of it getting the fixed-resolution feature as early as 2022, so I hastily assumed it must have been released in the meantime. Apparently not.
You can, and probably should, send feedback via the WiiM Home App. But since nothing has changed about this feature for so long, I wouldn't get my hopes up too high.
maybe its still in Beta, who knows :)
