steadyshot
- Mar 14, 2023
I am with onlyoneme here. Do not use the RME dac to test the jitter output.Since you said "measurably", what measurements do you have ? Thanks.![]()
Why so?I am with onlyoneme here. Do not use the RME dac to test the jitter output.
You know perfectly what I have, @onlyoneme . We could discuss forever about the meaning of "the same". Consider this, instead : "the same, or so marginal differences that it would be absolutely impossible, in any shape or form, that one single human on Earth would be able to hear it". And you obviously know that nor the WiiM Mini, or the WiiM Pro would produce any audible difference through Toslink on whatever DAC on the market by today.Since you said "perform, measure (...) the same", what measurements of the raw signal on the toslink output do you have ? Thanks.![]()
I guess I know. That's why I notice the lack of mentioned measurements.You know perfectly what I have
You said "perform, measure and sound 100% the same". Your explanation may justify using the word "sound" because it relies on people's ability to hear, but not "perform" or "measure."We could discuss forever about the meaning of "the same". Consider this, instead : "the same, or so marginal differences that it would be absolutely impossible, in any shape or form, that one single human on Earth would be able to hear it".
I doubt it's true, at least measurable differences are obvious. Since you don't have any measurements that would indicate the same or at least very similar quality of the output signal on toslink, I would call this an unjustified conclusion.And you obviously know that nor the WiiM Mini, or the WiiM Pro would produce any audible difference through Toslink on whatever DAC on the market by today.
If the Mini can output at the maximum bit rate of the service you are using, then there will be no difference in sound quality between it and even a £2,000+ device if you are just using it as a streamer. If the processor struggled to keep up, then that would manifest itself in glitchy playback with drop-outs and pauses, not a generalised reduction in sound quality.It is an interesting video because it attempts to answer the question most of us will likely have asked ourselves at some point, namely, if a streamer’s digital output is bit-perfect and fed into an external DAC, from a purely sound quality perspective is there any point in considering an expensive streamer over a cheaper one? All the streamer comparison articles I can recall have only concentrated on line-out SQ, so one that just compares the digital domains is to be welcomed.
However, like others here, I am surprised by Passion for Sound’s conclusion but that in itself is probably no reason to just dismiss his claims. The question is a really important one, both from a general (almost philosophical) perspective and from the specific viewpoint of the WiiM family.
As a long-standing Mini user who is happy with its digital output, I am not in a position to compare with other WiiM digital outputs and so cannot comment myself. Nonetheless, dispassionately confirming or refuting Passion for Sound’s conclusion is something of a priority for everyone who enjoys streaming.
I have just watched the Passion for Sound video, a reviewer I usually respect. He is absolutely convinced that the digital output from the WiiM mini is much poorer than from the Pro, which is a bit of a mystery and surprises me...
Last night I watched a video by YouTube reviewer Passion for Sound. I find him to be very thorough. He claims the Pro+ and Pro far outshine the Mini when they are used only as a digital streamer. He believes it is down to the Quad Core used in the two Pros vs the Dual Core used in the Mini and probably other circuitry enhancements in the Pros.
For those that have both and use them as a digital streamer only, what say you? Thanks.
Yes way. The Streamers are far better in the Po models and are therefore an upgrade...
I hear ya! I have three mini’s and am very pleased with the sound quality. I generally like his videos but found this particular one curious, which is why I started this thread. He essentially said the mini is a dog as compared to the pros when used as a streamer. I thought, really? No way, man. I have no intention of upgrading. Thanks. Wait a minute. I just said upgrade. When used solely as a streamer, as I use my mini, then the Pros are not really an upgrade, are they?
..Yes way. The Streamers are far better in the Po models and are therefore an upgrade.
..Passion for Sound has just released a grovelling apology for suggesting that there is no point in buying anything more expensive than a WiiM Pro, and now says that much costlier streamers are better if the rest of your system is high end enough. I think he will have got push back from some high end dealers who can see him undermining their business models. I call BS. I think a blind testing environment is needed when you get to this level of comparison.
I am using a similar DAC arrangement as him, using Chord components through reasonably high end amp and speakers. The sound is little short of astonishing. I have compared CD to WiiM streams with the same recordings and there is no noticeable difference. I suspect if there is a difference with higher end streamers it will be extremely minor and probably due to electrical noise transmitted along coax cables. That is why I use optical Toslink wherever possible.
Earlier in the thread I wondered why this seemed to be a no-go topic for hifi reviewers, especially given its importance to those who enjoy streaming. Maybe I now have the answer.Passion for Sound has just released a grovelling apology for suggesting that there is no point in buying anything more expensive than a WiiM Pro, and now says that much costlier streamers are better if the rest of your system is high end enough. I think he will have got push back from some high end dealers who can see him undermining their business models. I call BS. I think a blind testing environment is needed when you get to this level of comparison.
I would think about changing your DAC. It seems to be rather low quality.Just want to share my experience, which can be different from others as the environment is different. My Oppo supports HDMI, optical and coax. I have a Firestick, a min and a pro. Firestick is the cheapest solution. It can stream video, and music is still enjoyable. The mini connected to optical sounds better than Firestick connected to HDMI. Connected to optical, the pro has a larger sound stage and more bass than mini. For the pro, coax is better than optical. Instruments and voices can be heard more clearly. I have mix feeling about connecting a LAN cable to the pro. It has more bass, but with 5G WiFi, the sound is cleaner and more relax.
I was hoping comment #43 might nip such discussions in the budAnother epic WiFi vs Ethernet.
