EddNog
You’re claiming that Qobuz Connect sounds better than using the WiiM’s native Qobuz support playing the same resolution/sample rate version of the same track?While folks are discussing various connections aspects of Qobuz Connect via WiiM devices, thought I'd add some listening feedback.
On my tube monoblock system, it's a very nice, sizable audio improvement. I'm hearing additional depth and detail beyond any technical evaluation from albums in 192K by the Cars, Blondie to 44K recordings like Stevie Ray Vaughn Live at Carnegie Hall. Ran the room correction L/R again to capture the best match as well.
It's not only detail. It's a richer listening experience across the audio range. This is heard better on recordings such as jazz and classical. Definitely the best I've heard on Christian Sands' album, "Reach."
Will go out on a limb and say this is the best PCM performance I've gotten out of my system using the WiiM and to be fair direct from a Mac M1 Air via USB to the RME. Thank you very much Qobuz and WiiM! This is truly outstanding! YMMV
Related equipment: WiiM Pro, RME ADI-1 FS DAC, Schiit Saga+, McIntosh LS340, Richard Gray RGPC 400, 2 Cisco Meraki switches from FIOS fiber service (to the WiiM and 5v LPS, optical audio to the RME).
Both the Schiit preamp & LS340 speakers are recapped.
-Ed
