Yeah, her rhythm is perfectNice to hear your "woofer" is still operational![]()
See https://forum.wiimhome.com/threads/...no-in-tv-and-bluetooth-inputs.5420/post-90109My recollection as well. I think it has been quoted in the forum or perhaps in the WiiM threads over on ASR before the forum was setup.
Will the artwork also show?No. Your Ultra should show "Follow xxx" (xxx is the name of your Mini) and show what is playing as if it was playing locally.
This do however not always work but a relinking usually resolve it.
I don't have a Mini but a Pro+ I use for adding additional in/out to the Ultra in this way, so can't say if there is issues with the Mini in this regard.
Yes. Except that full screen artwork is not supported. There will always be text.Will the artwork also show?
I just ordered a mini. What is the best way to connect it to the ultra for optimum sound quality? I’m using this as a solution for lack of Apple Airplay.Yes. Except that full screen artwork is not supported. There will always be text.
Select the WiiM Mine device in the WiiM Home App "Devices" and then link it to the Ultra. That will play what is on the Mini on the Ultra also (24/48).I just ordered a mini. What is the best way to connect it to the ultra for optimum sound quality? I’m using this as a solution for lack of Apple Airplay.
Linking is not permanent. Just unlink the devices and they can play individually.Also do I have the option to play just to the ultra or do I always have to play to the mini / ultra group with this setup?
Just so I am clear, are you saying that I don’t have to use a cable to connect from the mini to the ultra? I just want to be sure.Select the WiiM Mine device in the WiiM Home App "Devices" and then link it to the Ultra. That will play what is on the Mini on the Ultra also (24/48).
Yes. All linking is via network (WiFi or Ethernet).Just so I am clear, are you saying that I don’t have to use a cable to connect from the mini to the ultra? I just want to be sure.
I am having an issue. I have everything linked properly and I’m getting sound however as the albums change via airplay. The artwork is not changing on the ultra display. It continues to show the artwork from the first song. Any idea what could be going on?Yes. All linking is via network (WiFi or Ethernet).
That you will need to raise a ticket for.I am having an issue. I have everything linked properly and I’m getting sound however as the albums change via airplay. The artwork is not changing on the ultra display. It continues to show the artwork from the first song. Any idea what could be going on?
Yes with Tidal it works fine. Artwork adjust as songs change. However with Apple Music it stays on the artwork of the first song.That you will need to raise a ticket for.
I don't use airplay (or anything from Apple), so cannot test that.
Does it work if you play something via the WiiM Home App?
Probably an issue with the AirPlay API.Yes with Tidal it works fine. Artwork adjust as songs change. However with Apple Music it stays on the artwork of the first song.
I have never used AirPlay, but presumably it is normal for AirPlay not to show artwork on the Ultra screen. The first thing that appears may be cached data. (Sorry if I'm wrong.)Yes with Tidal it works fine. Artwork adjust as songs change. However with Apple Music it stays on the artwork of the first song.
Getting album art over BT requires AVRCP 1.6 (Audio/Video Remote Control Profile) on both devices. Default for most devices is AVRCP 1.5.I have never used AirPlay, but presumably it is normal for AirPlay not to show artwork on the Ultra screen. The first thing that appears may be cached data. (Sorry if I'm wrong.)
Btw, Bluetooth does not show artwork.
Artwork appears ok on the Uktra when I Airplay to a Mini in a Mini+Ultra group but as reported, the artwork doesn’t change on the ultra screen when the track changes. I’ve submitted a ticket.but presumably it is normal for AirPlay not to show artwork on the Ultra screen. The first thing that appears may be cached data. (Sorry if I'm wrong.)
How is WiiM typically when responding to tickets? Should I just return the mini ?Artwork appears ok on the Uktra when I Airplay to a Mini in a Mini+Ultra group but as reported, the artwork doesn’t change on the ultra screen when the track changes. I’ve submitted a ticket.
