Completed Room Correction for Individual Channels
This setting effects boost and cut, despite it saying max boost
Well, it doesn't say max. boost, it says max. gain. And that refers to the absolute value. As I said, a design decision, not a bug.
As long as you keep the correction range below ~3000 Hz the UMIK-1 is usually flat without calibration applied.
I asked whether to point upwards or point straight ahead
Up to 1 kHz the UMIK-1 is pretty much omnidirectional, so there won't be any difference.
Usually, pointing straight between the speakers is the recommended way, but (somewhat ironically) as long as we cannot import any calibration files, the frequency response is actually flatter pointing upwards up to at least 6 kHz.
Here are the 90° calibration files for a couple of UMIK-1 samples at 90° (pointing upwards):
By comparison, here are the cal files for the same mic samples at 0° (pointing straight):
As you can see, at 90° these mic do require less calibration, so the error is noticeably smaller than at 0°. This is no longer true for higher frequencies above 6 kHz.
And my other pair
Unfortuantly makes it sound worse. I've also reset any boosts to 00db. Cool feature but I'll disable it.
And my other pair
Did you turn off EQ before running RC?
There is a bug in the Android app (241204).
Any plans to release L/R Room Correction WITH Sub/Bass Management on? Or is that impossible?
-Ed
Pretty sure it isn't impossible. Just a question of getting the levels right for the frequencies below the crossover. Hopefully WiiM are still working on it but unless they comment we have no idea. Apart from saying the initial results weren't good WiiM have never given any details about it. Modifying the target curve for each channel by dropping the level by 3dBb below the crossover frequency could be a step in the right direction.
