I'm not even talking about an auto correction mode which is quite a subject in itself..hihi...I care about room correction roughly 256,672 times more than about HD or bit perfect or Hi-res and 192 kbps.
Double that number regarding bankrupt MQA.
In that case I didn't catch the irony you're talking about.I'm not even talking about an auto correction mode which is quite a subject in itself..hihi...
just "simple" peq here... ;-)
"""new""" “announced” this peq 10.. but not yet this beta...People who beta test, are they sworn to silence, or are they allowed to discuss, and post pics?
Search the forum for “beta testing” and you’ll find threads on PEQ, Airplay Casting and Squeezelite where testing of beta programmes was discussed
For what they call "chirp" and "sweep" there is afaik a possibility. I do not have and do not want a subwoofer and because the manual says this option is mostly useful for such subwoofer setup I didn't even try it.I cannot say the same about Room Equalization Wizard and the UMIK-1. Results are very repeatable and have been helpful setting up my amp.
Does House Curve allow for measuring one channel at a time?
This forum is going to turn into the room correction complaint forum. For two speakers and stereo sound that will be a travesty.Not a single one of my House Curve (paid version) experiments have been successful. Conditions always the same. Ipad connected to an UMIC-1 on a heavy tripod for photographers. At the same place. In same height and same distance. Absolute silence. Tests on WiiM Pro via Airplay. Not a single measurement was like the one before. And the deviations were definitively too significant. Not even near to same results. Have to say my room does not create big problems. So if ever I expected only little improvements. What I got was worse. Every try failed. To avoid errors with an eventually defective mic I borrowed another from a friend. Same results. No recommendation from here ;-)
Will try a DSP hardware solution after a little research.
You are right. Sometimes the nursery child in me wins all contests.This forum is going to turn into the room correction complaint forum. For two speakers and stereo sound that will be a travesty.
In the meantime and after asking some professionals it seems my listening room is near perfect. Not planned, just coincidence ;-)Room correction - done the right way - can be a substantial improvement for 2 channel stereo.
if there is not much need... you might as well avoid...In the meantime and after asking some professionals it seems my listening room is near perfect. Not planned, just coincidence ;-)
Anyway, I'll give miniDSP or something like that a chance. Eventually this is the way to make things even better. But with HC I'm done, no trust any more. And too much bad things about read the last days. Where is smoke there is fire ;-)
The budget for 2024 isn't depleted yet ;-))if there is not much need... you might as well avoid...
we are only at the beginning of the year...The budget for 2024 isn't depleted yet ;-))
