Yes, I did it because there was a dip just before the crossover frequency and it was almost completely removed when I let the sub include a few frequencies above it.Subwoofer bypass mode.
That's unconventional, indeed. The resulting low pass filter slope will most likely be something between 36 and 48 dB/octave then. Unless you enable subwoofer bypass mode.
If you care about that sixty-something Hz dip and it remains, no matter what crossover frequency you pick, then probably the only way to really change this is to relocate the speakers and/or the sub and/or your main listening position. Playing with different filter settings might help, but it's all hit and miss.
I did try different crossovers but just the sub alone or main speakers alone did not help it.
