That looks much better, good work!View attachment 28289
I repositioned the speakers and sub to more 'optimal' positions now. It seems I may have to reduce the sub's volume somewhat - or shall I just let the room correction take care of that?
The 8kHz peak is ghosting picked up by your phone's built-in microphone (or it could be internal phone noise). Since this sound isn't coming from the speaker, you can safely ignore it.Hello
I have a question. When I use the room correction measurement with Wiim Amp Ultima (I'm a beginner, unfortunately), there's always a boost at 8 kHz. We've discussed this in several forums, but why does it occur for me?
It's a whistling sound, I'd guess around 8 kHz, so in the very high frequency range. It doesn't bother me at all when listening to music. How noticeable should it be?
And now I've noticed that the final correction probably isn't even showing the correct result! When I access the saved values, this 8 kHz boost is no longer visible in the modified measurement results.
I'm confused now.
Shouldn't this graph from my saved profile show the final result? I've shown a slightly different graph so far, and not the correct one, without the 8 kHz boost.
I've shown this screenshot in other forums where the frequency increased to 8 kHz. And that probably wasn't even the correct result? But here's a graph below, which comes from the saved final result, where the 8 kHz peak is no longer visible. Is the one from the saved graph relevant?
Teufel
And this diagram is from the saved final result, where the rise of 8 kHz is no longer visible.
Teufel Ultima 40
Elac Debut Reference DBR62
Why are you repeating the comments from another thread?So, Leute!
Ich habe gerade meinen Denon AVR-X2400H mit Audyssey verwendet, um meine Elac Debut Reference DBR62 und Teufel Ultima 40 Lautsprecher zu kalibrieren, und hier sind die Ergebnisse.
Nach der Kalibrierung klingt der Denon mit beiden Lautsprechern (Elac Debut Reference DBR62 und Teufel Ultima 40) deutlich besser als mit Wiim und seiner nutzlosen RoomFit-Funktion!
Ich überlege sogar, meinen Wiim-Empfänger zurückzugeben, denn die Wiim-Kalibrierung ist völlig sinnlos! Sie verbessert den Klang einfach nicht. Denons Messtechnologie Audyssey ist für mich deutlich besser! Bis jetzt! Wer hätte das gedacht?!
Hier sind die Ergebnisse.
... Teufel Ultima 40 mit AVR-X2400H
Elac Debut Reference DBR62 mit Denon AVR-2400H
And use a calibrated microphoneWhy are you repeating the comments from another thread?
The RoomFit works really good for me. Just need to set the measures to fit your equipment setup
Do I need to calibrate the microphone before using it? Or can I just plug it in and test it? Why do I need to calibrate it at all? Why isn't it calibrated at the factory?And use a calibrated microphone![]()
It is calibrated at the factory. It comes with a calibration file which can be imported into RoomFit. The Dayton Audio imm6C is probably the cheapest USB microphone. It plugs directly into the phone USB socket while the UMIK-1 connects via a cable.Do I need to calibrate the microphone before using it? Or can I just plug it in and test it? Why do I need to calibrate it at all? Why isn't it calibrated at the factory?
Are there alternative, cheaper microphones that are just as good? Which one is better than the microphone that came with my phone?
Hello
I'm confused now.
Teufel
Teufel Ultima 40
The bearded old fat guy who dresses in a red suit
Can I have the two microphones with associated calibration files on my WiiM Pro, or do I need to delete the IMM6 and its associated calibration file before installing the IMM6C and uploading its calibration file?
So you can't have calibration files for two different mics simultaneouslyIs this the person you're talking about?
Uploading the IMM-6C calibration file should overwrite and save it.![]()
Maybe not, but I can’t imagine too many people having that requirement, nor is reloading a calibration file that onerous.So you can't have calibration files for two different mics simultaneously
That's true, but @AlanB probably won't be using IMM-6 anymore.So you can't have calibration files for two different mics simultaneously
It will be interesting to see how the results compare with the new mic. When I used the iMM6 with 3.5mm jack the bass rolled off to a greater or lesser extent depending on the phone I used.That's true, but @AlanB probably won't be using IMM-6 anymore.![]()
He replaced his phone, so it probably doesn't have a 3.5mm port.It will be interesting to see how the results compare with the new mic. When I used the iMM6 with 3.5mm jack the bass rolled off to a greater or lesser extent depending on the phone I used.
You can actually have multiple calibration files imported into the WiiM Home App. But you need to manually pick the right one whenever you change the mic.
The device running the WiiM Home App is where the files are stored, not the WiiM device.
I know but the results from the new USB mic should still be better unless the new phone has the problematic mediatek SOC.He replaced his phone, so it probably doesn't have a 3.5mm port.![]()
