Sell me a Wiim Ultra
My processor has EQ/room correction- in some ways it's more advanced (per speaker EQ) but the auto system is trash, and it doesn't have enough presets. I have bass management in the processor plus I'm using a Outlaw ICBM-1 for the second speaker set so I have analogue Bass management there.
Per speaker EQ is available for the Ultra but not with a subwoofer yet. The main reason I bought the WiiM Amp was for bass management and then Room Correction came along as an added bonus.
I wouldn't be using the wiim sub out, it will be subwoofer out into a av pre amp. The AV pre amp digitises analogue inputs so I wouldn't use analogue out from the Wiim.
Unless I get another wiim pro plus/ultra for the other room which uses a stereo analogue pre amp
Not really. Have you used LMS recently? Its implementation of BBC Sounds and Radio Paradise, just naming two services, is so much better than WiiM’s current offerings.
I use the best of both worlds - LMS to index my local media (and in particular to use the two services I mention) and play to the squeezelite client in my WiiM Ultra feeding into my Linn MDSM/4. I also use Amazon Music on the Ultra which integrates well with Alexa and the Amazon Echos I have throughout the house. For me it’s not a case of either/or, but both LMS and WiiM
Got it, but if you are looking to simplify then using only wiim would suffice.
IF going the other route, the using Roon would be even better to get a really nice front end and music sorting for local files.
As he was asking why switch I thought he wasn't satisfied with current setup.
it seems more like you have decided you do not need a Wiim ultra and want us to change your mind? 😉
Your setup seems good and is working fine, so perhaps you could say what you are lacking currently instead and we could give you tips/suggestions?
OK with BF deals, sell me a Ultra. What benefits does the Ultra offer me over a Squeezebox touch?
I know of room EQ, also if it has presets that will allow me to use a room EQ preset for speaker pair 1 Celestion A compact and another EQ preset for speaker pair 2 Celestion A3.
But what else does it offer me?
Love the sub out on my. My tube amp doesn’t have one. Added a sub to go with my Wharfdales. Can’t imagine using anything other than WiiM. Amazing product
I'll move the sb touch from the cinema room . The EQ preset will be handy for the two speaker pairs
A warranty. Manufacturer support.
Wiim arrived seems decent.
I'd like track info to be displayed on the screen not just album art. Using lms
Swipe right and you’ll get track name and artist as well. Ok. It’s not LMS’ Material Skin but… ;)
Ah right got it. One thing that would be great if can choose the music by front panel like the sb touch
I had a Squeezebox Touch and a Yamaha WXC-50.
Now I have a Wiim Ultra.
Minus one box. Better ADC and DAC. Direct LMS input control from iPeng, and overall fewer «seams» in my setup.
There are however some app and remote features that I hope Wiim will learn and implement from both Yamaha and Lyrion.
Edit: I had a tldr moment so didn’t reach the end before posting. Congrats on your Ultra!
Done a couple of quick EQ responses with my two sets of speakers
One pair is celestion Compact the other A3. A3 are set to full range . Compact going though outlaw icm-1 with outlaw sub trim reduce sub volume as possible and crossover set to 80hz
Will need to think and alter crossover so it doesn't correct below speakers f3
Brother bought a Ultra also, the phone to Wiim BT is useful, as would laptop to Wiim BT, plus playing from USB stick/HDD and build database- so no need for a dedicated server, ie NAS or pi etc.
You can also use the Bluetooth output from a laptop with REW for room correction. Although I normally save the sweep files and play them from LMS.
I would send audio over HDMI directly, done that in the past- rather than deal with BT for things like that.
