BowsAndArrows
i'm using it with optical in + optical out. but to answer your question, there is no way to connect the S/PDIF ipurifier input directly to the WiiM coax output, cos they are both female ports??!Anybody using ifi spdif purifier with coax only on WiiM pro plus or pro ? How do you connect it ? Directly to the WiiM coax output or directly to the dacās coax in ?
you can connect the ipurifier's coax OUT directly into a preamp/amp cos that side is a male port.
