Test WIIM pro+ with different power supplies
I tested my iPower X I use on the WIIM pro on the Argon SOLO, not expecting anything because the Argon is supposed to clean the power by itself. Not so much. Immediate difference. So I had to get a second iPower..... I could pick that out in a blind A/B test (not a double blind, those are stupid)
Benchmarkmedia.com says, I quote:
"A well-designed switching power supply can be much quieter than a linear supply."
So the important words are here "can be".
A well-designed switching power supply can be as good as a LPS, maybe even better.
An who is convinced that the simple $ 2.50 plug-in switching power supply we get "for free" with a competitively priced WIIM Pro Plus is "well-designed"?
It is sufficient to make the WIIM Pro Plus work? Yes!
Is it better than a well-designed LPS? I do not think so!
Is it as good as a well-designed switching power supply, as Benchmark refers to? I do doubt it.
Greetings from Germany,
Alexander
Dear cc_rider,
I know this must be quite hard for you:
You quoted Benchmark, and YES, right now do live with that, what they said: ...."can be....".
;) + :D
Apart from being noisy to the device they are powering, switch modes also saturate the surrounding area with em radiation. Try holding a non-contact voltage tester near one (for testing for live wires in walls). It will start responding in quite a wide area. This is EM radiation that other non connected components will also pick up.
