Ultra 12 volt trigger issue
Any resolution? I also bought a ET-3 thinking my amp needed more current to trigger but still didn't work. I have now measured the 12V out and I am getting 0.01V directly form the Ultra. It's been 3 weeks and nothing from WiiM support.
No, ask WiiM support to get refund or get another device.
My trigger has not worked on some of the firmware upgrades but worked fine for a while now. Until today. The Ultra was on and the VU meter was dancing to the music but the amp was not on. I rebooted the WiiM and it worked (the trigger was turning on the amp). But when I changed software (from Roon to JRiver) it went dead again (Ultra was on but trigger had the amp off). After I once again rebooted WiiM, the trigger worked again.
Frustrating. This is a recurring problem which sometimes gets fixed. Unfortuately, it's back. I sent support notes in the past.
Brand new Ultra here. The trigger worked fine for about 20mn, then I changed a setting (screen off during standby, went from ON to OFF) and that caused my amp & DAC to turn off. Since then the trigger is dead. Rebooting doesn't help.
Waiting for WiiM to respond to my support ticket now
Mine was working normally after a reboot. Only the day of the new firmware was there a problem.
Until this morning. When I initiated some music, the WiiM Ultra display came on, but the amp didn't. I had to reboot again. Then I noticed there is a new firmware. But, all is well again after the reboot.
I too am having an issue. When I power on the ultra the amp comes on as expected. When I power off the ultra, the amp stays on. The cable is not the issue as I have tried several. If I unplug the trigger cable from the ultra, the amp switches off. The amp also has signal sensing that will see the signal from the ultra and switch on. After 12mins of no signal the amp will switch off, however the amp will randomly switch on with no input from me. Really annoying. I hope someone can help. I have raised a ticket with wiim.
I would not rule out an issue with the amplifier. One simple test would be to measure the Ultra's trigger output with a multimeter & see if the 12v goes up/down immediately with power on/off.
Just want to add that I received my WiiM Ultra last weekend and the trigger out seems to work perfectly with a Rotel RB-06 power amplifier.
I rebooted everything….WiiM & Computer and it fixed it.
Hi the trigger of my Ultra seems not to work. I measure 0,88v as the wiim is working and 0,14v as it’s off. I have unplugged it several minutes, tested different inputs and outputs with the same result. Ticket opened….
Can report the same issue on a just out of his box Wiim Ultra, which is a replacement for one that had the same issue...
I heard my relay click when initializing it on an old firmware, after firmware update, no clicks anymore...
This is very clearly a software issue.
Good evening, I report the same issue (amplifier doesn't goes off) with the Aiyima A20 amplifier, I don't hear any relay clicking. Is anyone else using the latest firmware experiencing the same issue?
Good morning, I have reached out both WiiM and Aiyima support, the latter explained me that "the trigger interface definition for WIIM devices differs from those currently available on the market, including our own. Consequently, the A20 amplifier cannot support WIIM triggering.
However, it is possible to connect only half of the trigger cable."
the trick works and looks stable in my case so issue solved, just wanted to share it (I have read about it elsewhere) in case it can be useful for other users
....., the A20 amplifier cannot support WIIM triggering.
EDIT: I figured out how to make the Wiim 12V trigger work with my Douk Audio D1 amp. It appears to be the same solution you found for the Aiyima. I had a common headphone cable with a stereo 3.5mm plug at the source end and two 3.5mm mono plugs at the earcup ends. Inserting one of the mono earcup plugs into the Wiim and the stereo source plug into the amplifier and it worked. It is likely a stereo to mono plug adapter would work as well but I do not have one.
This is of course not a solution if Wiim firmware is not sending a 12v trigger, but if plug compatibility is the issue it worked for me.
UPDATE:
I got a 3.5mm Mono to Stereo Adapter like this one and this is the correct way to make this hookup. You need the adapter along with a 3.5mm male stereo to 3.5mm male stereo cable. The adapter plugs into one end and that end plugs into the WiiM. The other end with the stereo connection plugs into the 12v trigger of an amp expecting a stereo plug. It works perfectly.
UPDATE:
Stereo?
Are you sure it's not MONO?
I make my own cables for the triggers, and they're always a mono signal with a mono jack at both ends.
Stereo? Are you sure it's not MONO?
I am sure that the fix is as I describe specifically for compatibility between the WiiM and Aiyima/Douk and similar current Chinese mini amps. The mini amps require a stereo plug. Certainly the signal out of the WiiM is not stereo, it probably has to do with the contacts within the socket of the amps.
This is separate from the issue discussed on this thread before post 34.
