Ultra won’t adjust below crossover and wondering why it wasn’t same as amp.You should find the RC on the Amp does work below the crossover frequency.
Who knows. I hope they don't remove it from the amp as well. I don't understand the logic of not equalising below the crossover. A sub is more likely to be able to handle it than the main speakers.Ultra won’t adjust below crossover and wondering why it wasn’t same as amp.
Is there a setting on app where I can choose that?You want PEQ options of
sub only
speakers only
sub & speakers.
No. That is ideally what you want, not what you get, yet.Is there a setting on app where I can choose that?
Why would I want that with PEQ?You want PEQ options of
sub only
speakers only
sub & speakers.
If I apply it manually then I do know the crossover frequency and I can choose which frequency range to cover and which to ignore. If I let automatic RC do it I'm still more worried about the frequency range than about which speaker is reproducing it.
I know that AVRs often offer independent EQ of sub and mains but never thought it to be beneficial. Just give me 10 band stereo PEQ and I will know best to what frequency range I want to apply it.
Yes, that's certainly one way of doing it, but I question it is the only "right" way. We're talking 2 channel stereo here where the sub is not really an independent channel, but just combined stereo. The most important target is to integrate sub and speakers as smoothly as possible. The integration should be reached first, RC comes on top of that (and surely can iron out some remaining roughness).Because it should be three channels. Left, Right, and subwoofer. The better EQ should send three sweeps, measure each one, then display each specific speaker response. Whether you use auto or manual entry is up to you. I like the Wiim offers EQ cut off frequency, maximum boost allowed. My processor doesn't do that. So that will be useful.
Two channel PEQ is already announced and it the one feature I've been missing the most, so far.Yes you can do manual PEQ entry, but they should be on individual channels. You don't want one PEQ on one channel to interfere with any others.
This could still be handled through frequency range settings. Even if these are not brickwall filters, of course, LR4 is pretty steep already and -24 dB one octave up or down is pretty much negligible in most cases. Would you personally really want to mess with the integration of two different room correction systems? I would not. And I'm sure the vast majority of WiiM's target audience will even less.Also you might have an external subwoofer EQ, ie minidsp- so you wouldn't want to EQ the subwoofer output- this is my case- as I have minidsp for the subs.
To be very clear on this: I don't buy this "DSP is killing the integrity of music and destroying the live-like sparkle" talk, not at all. However, even if I would: As long as the processing is done by the WiiM's only 4 core CPU (including the high pass and low pass filtering) the "damage" done by the DSP has already occurred, even if PEQ is only applied to the signal that's routed to the sub out.Or you like PEQ, but only for the subwoofer, you like the main speakers without EQ, you want "pure mode" for L/R
Option 2 is obviously something completely different, not offered by WiiM so far, so completely pointless to argue about.1) L/R downmixed into one single subwoofer, then filtered somewhere, either at the DSP level (high pass or just filtered but not speakers high passed) or sending sub full range and using the subs own crossover.
2) Dedicated left signal, and dedicated right signal subwoofers
Real question: Did you bother reading what I wrote? I've been talking about the THX standard and about what is optional in HT. There is no requirement to mix bass below the crossover frequency to the sub. It just can be done and it makes sense and that's exactly what I wrote.LFE + <speaker crossover = Subwoofer
LFE is the dedicated low effects mix
Bass from each speaker below the crossover point is redirected to the subwoofer(s)
You're not going to feed the WiiM analogue output to any main speakers then? Yes, you could split that signal of course and then use a MiniDSP to feed another amplifier to feed the mains with a high pass filtered signal. Lots of things one could do. But this is a thread about the WiiM Ultra, which features bass management for one sub exactly.Actually option 2 is entirely possible with a Wiim. Use left and right pre outs into two subwoofers. Then use the subwoofers own crossover.
To the best of my knowledge 120 Hz is not the crossover frequency for the sub. Different crossover frequencies for mains and sub usually don't make any sence. 120 Hz is the brickwall filter for LFE content, which is then split into sub and mains signals at 80 Hz. See here:THX standard is 80hz for speakers, 120hz for sub LPF. Speakers are set to 80hz once you press THX (I have a THX AV pre) so <80hz from all channels is redirected to the subwoofer + LFE.
The Misunderstood 0.1 LFE Channel in 5.1 Digital Surround Sound - HomeTheaterHifi.com
In 5.1 digital surround sound, the 0.1 channel is called the LFE or Low Frequency Effects channel. While in the commercial system it is referred to as the subwoofer channel, this is not necessarily true for home theater setups.hometheaterhifi.com
I don't doubt that it can be done. It's just not the main focus of owning a WiiM Ultra or WiiM Amp for the typical user.Probably more issues than it's worth but if someone needs it that way..
Yes, and the reason is that the AVR can do the integration better than the sub could do, using symmetrical high pass and low pass filters.In a HT system when using bass management in a AVR, the crossovers in the actual subwoofer plate amp should be bypassed or set to maximum.
I use crossover settings other than 80hz for some of my speakers - small 60hz for L/R. Some others are 70, 80 or 90hz. 120hz for sub LPF
