Updated Products Roadmap
L/R RC is great. Most of us do not have symmetrical rooms or the possibility to set the speakers up symmetrically in a symmetric room.
So hear me out…
I was able to make L/R correction work even with bass management!
Your mileage may vary, but since I have an SVS SB-3000, which has 3 PEQ bands in its DSP plus room gain compensation (a fourth, LS filter with fixed options), and adjustable crossover slope, I set the room compensation in the range of 50Hz to 500Hz and ran room compensation scans over and over while tweaking the sub DSP controls (with Bypass turned on in WiiM’s Subwoofer settings so I can use the subwoofer’s low-pass filter instead of the WiiM’s fixed 24db/octave slope) until I only needed one adjustment (at 88Hz) under the crossover point (100Hz):
Then, I turned off the subwoofer entirely, adjusted the Room Correction range limiter to 130Hz-500Hz, and then ran it with Left vs Right and got these left and right adjustment curves, whereby I picked one inconsequential adjustment from each to replace:
And so I turned the Bass Management/Subwoofer back on and finalized my left vs right EQ like so and it sounds fantastic:
-Ed
So hear me out…
-Ed
Thanks for sharing something interesting.😉
Here's the way I'm thinking of doing it now.
  1. Connect two subs to the WiiM line out.
  2. Run L/R RC with frequency range 40hz-120hz.
  3. Capture the results.
  4. Disconnect the subs from the WiiM and run a L/R RC on the main speakers. Frequency range 100~120hz-4khz.
  5. Capture results.
  6. Turn off all bands above 500hz from the main speaker PEQ and insert the sub PEQ values there instead.
  7. Fine tune while measuring microphones.
(I have two subs connected to the Pro line-out and main speakers to the Ultra, so I'm waiting for the Pro L/R RC to come in.)
  5. Capture results.
That is a cool way to utilize multiple WiiMs! Unfortunately, I tried doing something kind of similar (used Grouping between Ultra and Mini with the Mini feeding my spectrum analyzer), and it worked great for music while…spectrum analyzing…but when I hooked my TV up to the Ultra’s ARC input, I discovered that Group playback ruined the Ultra’s ability to keep audio in sync with the video. As soon as I ungrouped the Mini from the Ultra, the sound over ARC was in perfect sync with the video, and the moment I regrouped with the Mini, the audio went way out of sync again, so Grouping makes ARC unusable.
-Ed
-Ed
I don't have Ultra connected to TV, so no problem, but as you said, there is a delay when grouped.
The latency will improve to 60ms~100ms when the low latency multi-room mode that is in beta testing comes out, but as I recall the Mini is not supported...
So hear me out…
-Ed
Explain to me why this is required at all?
Cant you just do the RC with specific range (Excluding below 100Hz) and then once RC is done enable your sub-out and adjust them via their DSP?
My sub is limited to 3 adjustments, and it needs one more to get it just right. Also, I am relying on the WiiM’s room correction to figure out what 4 total adjustments I have to apply to my subwoofer.
-Ed
-Ed
Then I understand :)
For me it was 4 but the 4th was so minor I just ignored it, did not cause any "noticeable" issues.
Personally I ignore it if it's a -+3db or less, my bass issues are in the +23 range :D
Are you using your phone as a microphone?
I am using a UMIK-1 plugged into the iPhone via a USB-C cord (iPhone 16 Pro which has USB-C port).
-Ed
-Ed
In that case I think it would be easier for you to measure your subs using the ”House curve”-app, and adjust much faster either in Subs dsp or via Wiim.
Roadmap updates seem a bit moribund, as is news on long awaited new features like smart presets, persistent groups, DLNA casting etc. Any chance of an update soon? Thanks
I think if they release a firmware and that feature was in roadmap that they should update the roadmap as well. This will help the user based up to date and eliminate the tagging and sending message to wiim.
That would be nice, but they already do more than most other companies so I can forgive them for this ;)
By the way has anyone of you seem the BlueSound forums?
Seems there is only one single guy moderating everything, "Tony" is his name, he must be swamped!
A wise green little man in a galaxy far away once said "Have Patience You Must"
On this forum you'll be the first to hear 😀
Not sure what you mean but I was just wondering when the WiiM amp roadmap be updated. It also states, on this forum, that DLNA cast would have been ready by 10/30.
