steadyshot
- Mar 14, 2023
So why pro is audiophile grade and mini is not ?The current pro webpage states:
WiiM Pro
Versatile Audiophile-grade Music Streamer
WiiM Pro
You submitted already your finished calculation in writing to WiiMs DB?It costs about $250 Wiim can design something much better for $300
A new marketing team?So why pro is audiophile grade and mini is not ?
If you're after a reasonably sensible answer, maybeSo why pro is audiophile grade and mini is not ?
No, I'm just saying that based on the little miracle they did with the pro. it seems that in wiim they manage to give more for the same money. I don't know how to calculate anything but I imagine that could be the price targetYou submitted already your finished calculation in writing to WiiMs DB?![]()
Agreed. Except the mythical jitter part, the answer from the "meassurers" to all unproven, only in special ears appearing and always unlistenable issues.If you're after a reasonably sensible answer, maybe
The pro has a (slightly) better outout stage
The pro has less jitter, iirc
The pro has coax out
The pro is a 'proper' bit of kit, being a box, not a puck
And whatever Brantome said too...
It was a joke, hope you read it as it was meant.No, I'm just saying that based on the little miracle they did with the pro. it seems that in wiim they manage to give more for the same money. I don't know how to calculate anything but I imagine that could be the price target
Nothing mythical about it. This is the Jittery Unicorn, which is also a real animal.Agreed. Except the mythical jitter part, the answer from the "meassurers" to all unproven, only in special ears appearing and always unlistenable issues.![]()
Still don't hear itNothing mythical about it. This is the Jittery Unicorn, which is also a real animal.
Because optical digital sockets are fragile.So why pro is audiophile grade and mini is not ?
You won't find a difference between their "audio quality" as they're both bit perfect over optical. And what your range of kit might be comparing is the quality of the DAC output which is analogue and not delivered over the devices' optical output.However I did not find a single report or instance on the internet for wiim pro having better audio quality through optical compared to mini.
No that is only for digital stage . Primare and ifi zen stream have no DACs .You won't find a difference between their "audio quality" as they're both bit perfect over optical. And what your range of kit might be comparing is the quality of the DAC output which is analogue and not delivered over the devices' optical output.
The people who will buy it if it delivers the hoped for better DAC and analogue performance and is reasonably priced compared to the Pro will be those who would have otherwise bought an external DAC costing say $100-200 dollars or more - now they can have that in one box. As I may have already said, some might view this new Pro as what the original Pro should have been - an upgrade from the Mini with a better DAC and connectivity.All of sudden till brantome said pro+ only improvement was internal dac and leave everything on pro without additional connection. I’m sure this will cost more than pro but who will buy this knowing we use its coax/spdif to connect to external dac. I don’t think pro+ will sell well in comparison to pro. Most external dac that user used will be superior to the improvement on what will incorporate. They could atlist add usb out then will buy it.
What I keep saying like a caller in the desert. The DAC is important, but only if the rest of the gear can handle it accurate. F.e. even a 1k DAC will be not able to better a weak amp or speakers. So as I said so often. Saddle the horse not from the tail!No that is only for digital stage . Primare and ifi zen stream have no DACs .
Until I hear I will keep my reservations as for how much the digital part plays a role in final audio quality .
