He is comparing it to bit perfect streams from other streamers into the same dac.So, did I hear this correct in test #3 that he was somewhat critical of the Pro’s sound? The Pro’s delivering a bit perfect stream over spdif into his intervening DAC so isn’t the “sound” down to that, not the Pro?
And the same time he is comparing one bit-perfect streamer to the another one tested year ago, and he tells which one sounds better... Not sure if to congratulate or to commiserate.He is comparing it to bit perfect streams from other streamers into the same dac.
In which case they’d sound identical - how could it be anything other than that? If it did sound different, he should get a better DAC as the one he has is therefore incapable of handling any issue in the reception of that bit perfect streamHe is comparing it to bit perfect streams from other streamers into the same dac.
He should ask onlyoneme to suggest him a good dac.In which case they’d sound identical - how could it be anything other than that? If it did sound different, he should get a better DAC as the one he has is therefore incapable of handling any issue in the reception of that bit perfect stream
Can we keep the discussion impersonal please? We can disagree without pointedly singling out other members who don’t share our opinion.He should ask onlyoneme to suggest him a good dac.
He uses Ares II, hardware that people have complained about compatibility issues with the Pro if I remember correctly. It's also a kind of fifo reclocking DAC, so its behavior can differ for particular streamers when it has to handle clock differences.In which case they’d sound identical - how could it be anything other than that? If it did sound different, he should get a better DAC as the one he has is therefore incapable of handling any issue in the reception of that bit perfect stream
For me that would make it not fall into the class of a modern competent DAC but I could see that argument being turned round to criticise the sourceHe uses Ares II, hardware that people have complained about compatibility issues with the Pro if I remember correctly. It's also a kind of fifo reclocking DAC, so its behavior can differ for particular streamers when it has to handle clock differences.
Bitperfectness is not a guarantee for sounding the same. There is also the issue of timing which is handled by the sending device while using s/pdif. There is a reason people want to see a USB or Is2 output in a future WIIM product (I don't think there will be, but who knows). Those methods allow the receiving DAC to handle the clocking. So the clocking done in the WIIM is crucial when using a digital output. This explaines why it sounds different when using the app or the chromecast, or when it is resampling the stream to a lower sample rate. The more the Pro has to do, the worse clocking gets. It probably interferes with the effectiveness of digital filtering in the DAC.In which case they’d sound identical - how could it be anything other than that? If it did sound different, he should get a better DAC as the one he has is therefore incapable of handling any issue in the reception of that bit perfect stream
Modern DAC or not, I just don't trust his statements about perceived differences in sound quality.For me that would make it not fall into the class of a modern competent DAC but I could see that argument being turned round to criticise the source![]()
It is as far as the receiver uses the same clock as the sender.Bitperfectness is not a guarantee for sounding the same.
A DAC can sync to the recovered clock. A well designed DAC will do that with a proper jitter suppression to maintain bit-perfect path in the digital domain.There is also the issue of timing which is handled by the sending device while using s/pdif. There is a reason people want to see a USB or Is2 output in a future WIIM product (I don't think there will be, but who knows). Those methods allow the receiving DAC to handle the clocking. So the clocking done in the WIIM is crucial when using a digital output.
Source of the file doesn't matter if the audio stream is unaltered during the decoding process.This explaines why it sounds different when using the app or the chromecast
Can you explain this further?The more the Pro has to do, the worse clocking gets. It probably interferes with the effectiveness of digital filtering in the DAC.
As already mentioned above, please keep comments a bit less pointed - “if you can” is unnecessarily provocative.Explain it if you can.
Everything that causes more processing will affect the sound. The higher end your gear is the more critical it becomes. On lower end gear there are usually more disturbing factors that will mask differences between different streamers. Meanwhile this will all sound okay to the average Joe so many companies will see no reason to invest in perfection when good enough is good enough. We've seen this throughout audio history.It is as far as the receiver uses the same clock as the sender.
If you can suggest something less "provocative" I will use it instead. English is not my native language as you could see already.As already mentioned above, please keep comments a bit less pointed - “if you can” is unnecessarily provocative.
All the time I face situations when something seems to sound better or worse than something else, or lets say "different". Sometimes it's a fact, sometimes just an impression.So, and I explicit don't mean it as a provocation: Did you never had or heard a component which sounded good for your ears and has more or less bad figures? Or is your conviction that the better measured is the better choice in each case because it can not be what is not allowed to be?
If you do not trust in "perceived" differences I am sceptic about such a black vs white.
Thanks. “Can you explain this further?” would have been sufficient. “If you can” comes across as patronisingIf you can suggest something less "provocative" I will use it instead. English is not my native language as you could see already.
Do you think that the audio stream sent from my PC to my DAC will differ when my PC CPU is occupied in 10% and in 15% for example?Everything that causes more processing will affect the sound.
Not in the digital domain. Modern streamers and DACs have achieved a sufficient level to deliver an unaltered audio stream from the source to the DA conversion process even in case of relatively inexpensive devices.The higher end your gear is the more critical it becomes. On lower end gear there are usually more disturbing factors that will mask differences between different streamers.
