DAB is mostly a European thing with limited coverage in Africa, Asia and Australia. Probably not sufficient worldwide interest.Would adding a DAB+ tuner be a big challenge?
Digital Audio Broadcasting - Wikipedia
en.m.wikipedia.org
Looks perfect, but I would also like bigger space around the in/outputs so we dont need to buy a bunch of new cablesDigital only streamer
Am I missing something?
- Airplay
- Chromecast
- Ethernet
- Wifi 6E or higher
- USB in/out
- Optical in/out
- S/PDIF coaxial in/out
- HDMI Arc
- HDMI display out
- External power supply
Most of that stuff is on ultra. If you don’t like the dac built on ultra you have flexibility to use its digital out that include toslink, coax and usb. Since airplay is not included you can use Bluetooth and get same lossy quality. Wiim want to simplify everything in one box and has the ability to bypass dac if you don’t like them.Digital only streamer
- Airplay
- Chromecast
- Ethernet
- Wifi 6E or higher
- USB in/out
- Optical in/out
- HDMI Arc
- HDMI display out
I2S output?Digital only streamer
- Airplay
- Chromecast
- Ethernet
- Wifi 6E or higher
- USB in/out
- Optical in/out
- HDMI Arc
- HDMI display out
DSP?Digital only streamer
- Airplay
- Chromecast
- Ethernet
- Wifi 6E or higher
- USB in/out
- Optical in/out
- HDMI Arc
- HDMI display out
Like dsp simulating the sound of concert hall?DSP?
I think it falls more in the line of EQ and room correction. Would be great to see an improved RC with convolution filters etcLike dsp simulating the sound of concert hall?
Didn't you just name the competition?A fully digital streamer amplifier, they call it PowerDAC, it is not analog class D. Examples are SMSL Q5 Pro, SMSL VMV A2 or Lyngdorf. It would be a product without competition.
Oh yes, they absolutely are.Digital amplifiers are not class D amplifiers.
I would like a power amplifier dedicated, in terms of appearance and characteristics, to the Wiim Ultra, something similar to the NAD C268 or C268.
Add something like LDAC to the list. Imo great as a secondary option giving some extra flexibility and more use case coverage.Digital only streamer
- Airplay
- Chromecast
- Ethernet
- Wifi 6E or higher
- USB in/out
- Optical in/out
- HDMI Arc
- HDMI display out
You can take an example from them, but the Wiim amplifier should be different from it.Eversolo just got their matching power amp to their latest steamer ...hopefully we got ours soon !
Understood. I won't bother you again.I am writing in a simple way about amplifiers working on a digital signal from start to finish. The digital signal enters the amplifier, and the analog signal is created only on the filters on the speaker connectors.
There is no need to explain more.
... is plain wrong. Just to make sure that nobody gets confused and jumps to false conclusions. Fact: Digital amplifiers are class D amplifiers that cannot use feedback to improve their imperfections like class D amps with analogue input. I'm sure that WiiM know thisDigital amplifiers are not class D amplifiers.
There are already streamers with the same Axign digital amplifier as the Sabaj A30a: Powernode edge , Marantz M1You can take an example from them, but the Wiim amplifier should be different from it.
It can be a choice: integrated amplifier and mono power amplifiers. Eversolo is still an analog amplifier and there are many similar ones. There are many analog class D devices based on Hypex, Purifi etc. to choose from.
But if Wiim were completely digital, it would be above the competition. It would not need a DAC, because it would be a DAC itself. Even Mini could be a good source with a preamplifier.
I am currently looking for such a used amplifier, but it is very difficult, because people do not sell them. That says something. I've only seen one Sabaj A30a, but I don't like it.
If Wiim announces such a project, I do not buy an amplifier, I just wait for Wiim![]()
