What products you'd like to see WiiM produce?
How about a surround sound processer that can decode 5.1 or higher video audio. It would have output for powered sub and amp output for center channel. Line level outputs to a pair of WiiM Amps to drive Front and Rear speakers.
That product would be a complete and utter failure. LOL
C'mon, give us a WiiM Amp Ultra already.
- larger screen with proper navigation of playlists
- finetuned phono preamp
- optional "direct" mode for the analog inputs so they don't get digitized, but sent directly to the amp circuit
- make the phono preamp switchable so it can be changed to a 2nd line input, allowing the use of an external phono preamp
- USB C port for connecting it's internal DAC directly to a computer, tablet or smartphone
- Slap in some Hypex or 3E audio Class D amplifier module ;)
- Airplay? 👀
I would love to see some small speakers with Wiim technology "build in" to place those in rooms where is no need for a bigger system and to avoid double cabling/power to feed the receiver, amp and speakers.
Something like a Google Nest or Nest Mini in kind of size - maybe with an additional physical in/Out Like the Wiim Mini... Or in other words: The Wiim Mini with some speaker on top would be dope and i wouldnt hestiate to replace my Nest Audios for sure.
I also heard of the AudioPro cooperation - but even the A15 is kinda big and a touch "too much" for some cases - and the Wiim Editions are barely hard to find, at least in Europe.
A speaker line by Wiim would warm my heart - from small budget ones up to more capable units...
Compact CD transport with software access to Musicbrainz database
The "transport" should then be via the LinkPlay (WiiM) network connection in addition to USB and S/PDIF outputs.
The CD player shall be a real WiiM device but with software for CD metadata lookup and ripping instead of the streaming part.
Control shall of course be via the WiiM Home App including the us of the metadata for album art display and track selection.
Here is my two cents:
A kind of WiiM Ultra Evolution or WiiM Deluxe (suggestions for name :) )
The base would be the features of WiiM Ultra but with the following add-ons / upgrades:
- A screen of 8.8" 1920x480 resolution (an HDMI video out option would also be a good thing or an alternative), implementing vu-meter costumization, more screen options / costumization; new
- Two sets of analog line-out outputs: both configured independently as fixed or variable; new
- a very good headphone amp; upgrade
- an even better internal DAC; upgrade
- very good external power supply (if possible option for linear PS); upgrade
- 2 line-in inputs + 1 better phono input (alternatively 2 or 3 line-in inputs); upgrade
- 2 SUB-out: configured as mono or left/right; new
- If possible, an USB-in for using WiiM as DAC; new
- Support for EQ auto-correction based on FIR Filters (option for supplied calibrated microphone); new
Definitely a CD drive in the same dimensions as Wiim Amp/Pro/Ultra with an optical and RXA output. Can be operated via the Wiim remote control and a front display.
Actually no need for outputs if used in a WiiM setup. Just linking to other WiiMs would do it. So a simple CD transport with focus on the drive quality.
a media server, specifically music. Something like Roon or Plex Server but dedicated for WiiU products
I'm sure it's been suggested, but I'd like to see a mid sized full featured dac/streamer with amp for 7.2 setup. Basically everything in one solution in a smaller and lighter footprint.
Nice improvement will be using room calibration with slider from 0% to 100%. User will decide what will be the usage of calibration EQ. The same like in Focal Bathys headphones where Mimi calibration profile is used.
I think there's a reason why slimline AVRs never sold in numbers. And why almost none is left in the shrinking AVR market.
This is just an observation, no personal judgement.
For me, I think they could be substantially less bulky.
Look at the size of stereo amps from Fosi, WiiM and co. Look at the size of a WiiM Mini, with can output and receive wirelessly.
Having a decoder/transmitter/3 channel amp in the size of a WiiM Ultra is more than doable. Add wireless rechargeable rears.
Bingo!
Soundbars are very popular. That’s the competition.
No offense taken! When I began my recent hifi journey just a few months ago, I had to work with the limited space I had, so this big Denon AVR receiver was just too bulky to fit anywhere! I honestly didn't know about streamers and mini amps etc. I just love these new products that can fit in your hand and deliver adequate power with amazing clarity and depth!
