Per channel? Into 4 ohms or 8?I would like a class D power amplifier of at least 250 watts
Might this go some way towards that?Wiim AVR PRO:
It would be great if Wiim:
This would keep the product line tight and no need to build massive all in ones. 1 AVRPRO flexes to fit larger systems, just add standard Wiim Amps. Make it all modular/configurable for those that need it.
- Start with offering a standard AVR DD5.1 based on Amp Pro (same inputs, HDMI earc in, dolby processing, etc)
- 5 channels of amplification + subout
- Keep it simple, no video processing or HDMI passthrough...just all downstream audio via HDMI earc
- Allow on the fly, electronic bridging of 4 channels to 2 channels for higher power 2.1 music listening mode. (no idea if this is possible but it would be awesome)
- Then create a configurable stacking interface where we can add additional amps connected via digital out from AVR Pro (acting as digital pre-pro) to secondary amps to handle Atmos, DTS, etc. For example:
- Amp Pro 2.1 (2 height or 2 surround and another sub)
- AVR Pro 5.1 (Heights, surrounds, passive sub and 1 sub out)
- Other future amps
That would be dream product to me, no idea if its feasible.
You're kidding meMight this go some way towards that?
Setting Up a WiiM Dolby 5.1 Surround Sound System
The WiiM Amp Pro and WiiM Ultra support Dolby Digital Audio, making them perfect for building a 5.1 surround sound system. A 5.1 system creates an immersive audio experience by delivering sound from multiple directions. This setup is ideal f...faq.wiimhome.com
Wiim AVR PRO:
- Other future amps
TVs output to soundbars without video over earc just fine. It keeps the cost and complexity low, why deal with video when you don’t have to…and…WiiM apps are fantastic, why would I want to use a TV when I could use a touch UI from my phone.That would be a failure . No video pass through? Lol. So basically connect a BD player and you get no picture to your TV. Brilliant.
Or you can't setup via the tv
Digital out wouldn't be allowed as that will break copy protection
And adding more boxes just to expand 5.1 to 7.1? Nah
Just have a avr with enough channels, either internal amps or pre outs.
Or something 16 channel AV pre amp out of the bat
E-ARC has it own issues, not all soundbars have ARC/E-ARC, not all devices have it, people also use monitors for their TV's. Also not all TV's pass all sound formats, and as sound formats change you won't be able to decode them. On my setup it was causing loud clicks and pops, not locking onto HD formats over E-ARC, even though both TV and processor support them. Problem went away when I put source-->processor--->TV
So no...just no.
And without phone/app, your device is totally useless. You don't know in a few years support will be ended, app no longer works, so how do you set it up?
Also need OSD for volume change, it shows onscreen. Or for displaying codec information
given the positioning and the audio resource concerning wiim... if already significantly improves the adc stages and integrates a balanced qualitative output...and more care for what already existsThe Superultra should have:
ADC performance as good as its DAC’s.
Differential analog input and output in addition to the single ended.
Two digital inputs.
Ditch the phono stage. Enthusiasts will use their own.
the fantasy that accompanies wiim which would be that I would have "everything for cheap!!"...I hope the little $50 minidsp adc toslink will live up to its promises... ;-)
Be prepared to pay for nothing. XLR is expensive and the benefits are marginal.Differential analog input and output in addition to the single ended.
