I expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.Sorry. You are confusing me. What do you expect to hear?
Eric’s lead guitar is left!I expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.
There are several different mixes of that song. Maybe you are used to some other mix?I expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.
Hopefully if the OP plays the test track I posted, we’ll know if there’s an issue with the WiiM device or with the mix being playedThere are several different mixes of that song. Maybe you are used to some other mix?
I have never heard one that moved Eric’s lead from the left!There are several different mixes of that song. Maybe you are used to some other mix?
Unless you were Ringo on the drums behind himI have never heard one that moved Eric’s lead from the left!
Maybe the OP has one, or maybe the line out of the Brennan B2 Harddrive player has always been swapped?I have never heard one that moved Eric’s lead from the left!
You assume it was played live in the usual band config which I think is highly unlikely. Ringo could have been in another room.Unless you were Ringo on the drums behind him![]()
They say they’re streaming from QobuzMaybe the OP has one, or maybe the line out of the Brennan B2 Harddrive player has always been swapped?
That’s easy to test. Just disconnect one channel at the output.Maybe the OP has one, or maybe the line out of the Brennan B2 Harddrive player has always been swapped?
That is wrong! Eric’s guitar is leftI expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.
This is how it was mixed,The WiiM via Qobuz is in reverse.I expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.
Don’t believe AIThat is wrong! Eric’s guitar is left
But that is not how it is.I expect to hear it when streaming as it was mixed,lead guitar right channel.organ right channel .drums left channel acoustic guitar slightly left.
It's not the only track or tracks being produced in reverseThere are several different mixes of that song. Maybe you are used to some other mix?
