WiiM Pro Ethernet light
Astanislaus
The Ethernet light on the back of my WiiM pro isn’t lighting up. Is this supposed to be flickering like the lights on the back of a router? I have the unit set to Ethernet and not wifi.
I can't answer that, I can only confirm that mine don't light up either!
Maybe it's just a standard part and was too expensive to wire it up... ;)
Where is the Ethernet light?
I don't know where it is🤔
But, I remember seeing the inside of the LAN socket glowing.
EDIT: Verified my pros. Nowhere does it glow.
It seems that I mistook it for another device.
