WiiM Pro Firmware v4.8.626448 Update - Aug 16, 2024
Please review the WiiM Pro update release notes below. If you encounter any issues, feel free to reach out to us.
4.8.626448(In Progress)
Release date:
8 / 16 / 2024
What's New:
  1. Per-Channel EQ: Set parametric EQ settings for left and right channels individually (requires app version 2.10.7 or later).
  2. Pre-Gain Feature: Added logic for Pre-Gain functionality. Compatible with app version 2.11.0 and above.
  3. Enhanced Stability: Fixed crashes with Spotify Connect and TIDAL Connect.
  4. Refined Input Auto-Sensing: Enhanced for smoother audio transitions with reduced delay.
  5. Output Change Enhancement: Preserves the playing queue when switching audio outputs.
  6. Stabilized Wi-Fi Connection: Updated the Wi-Fi driver to enhance connection stability.
  7. Bluetooth Playback Upgrade: Enhanced Bluetooth playback to reduce latency and eliminate stuttering issues.
  8. DSD Playback Enhancement: Now supports playing DSD audio tracks in DFF format.
  9. Soundtrack SDK Enhancement: Upgraded for a better listening experience.
  10. Playback Improvements:
- Fixed TIDAL playback skipping and stopping issues.
- Resolved Bluetooth playback distortion over long periods.
- Provide the correct playback index for the app to display.
Bug Fixes:
  1. Playback Enhancement: Minimized playback latency.
  2. Squeezelite Enhancements: Resolved issues with artwork display and connectivity with the latest Logitech Media Server (LMS).
  3. Pop Noise Fix: Reduced pop noise for Spotify Connect and TIDAL Connect.
  4. General Enhancements: Various bug fixes and performance improvements for a smoother experience.
If I remember correctly, only the Ultra is expected to accept multi-channel input, so far. But don't count on my clouded memories.
It's here, but my Ultra has been stuck in customs for 2 days while they dream up what to charge me. lol
I have some DSD256 files, but can not test since my DAC is hooked up optical DSD64 (DoP). would need to be USB to get 256.
USB on Ultra maxes out at 24/192 like its coax and digital outputs
If it is converted to PCM, it depends on what sample rate the DSD256 is converted to if it is converted. Give it a try and see what happens.
All my DSD is DSD64, the 256 was for a test, but the app doesn't see DSD at all.
Thanks for doing the test. Maybe it only accepts DSD64. Wiim has, as far as I can tell, not confirmed what DSD sample rates are allowed.
As soon as I can figure out how to get the files to play on the pro, but my Ultra just cleared customs, so will swap out soon.
The Home app on Windows is not seeing any DSD, DSD64 or 256. the files play in Plex Windows and I can see them on the Plex Android TV app, they do not play, just "Error playing this file" I will try the Plex beta when I get the Ultra since they want the MAC address, I would rather wait on the new unit.
Plex does play all my DSD on the PC, DSD64/256
