i'm just trying to see if there are any patterns here that we can try and replicate... just to be clear when you are referring to S/PDIF you mean toslink/optical and not coax (cos they're both technically S/PDIF - but obviously there is no coax in so...)
if i understand the issue correctly - the swapped channels - once it occurs - it stays that way until you either restart the WiiM or in
@noony's case starting a new application on the PC for audio then it fixes it??
![Face with spiral eyes :face_with_spiral_eyes: 😵💫](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f635-1f4ab.png)
have any of you tried to see what happens if you keep using the device in this "channel-swapped" state to see if the system randomly reverts to functioning normally again?
and according to
@D1N0 this is not isolated to optical in. it also occurs when streaming? in this case - with streaming - have you noticed this happen at particular times? (
@noony suggested when audio is paused for a moment) does it occur with all streaming services??
it seems really strange. i've been using optical out from many streaming sources and never once experienced this issue.
