Over the last few months my WiiM Pro is constantly moving off Ethernet and back to WiFi. It was fine initially - I guess a firmware update (about 3 or 4 ago) seems to have regressed things.
I have two WiiM Pro, both do the same, one is a bit worse than the other. Usually I've not even used my WiiM since the reboot, and then later find it's moved.
On a reboot both will work with Ethernet fine for a while, then at some point (even though I switched WiFi off in app) they go back to connecting to WiFi. There is no way to clear the WiFi settings, or return to Ethernet - you have to reboot.
Is anyone else getting this? Are WiiM aware of this?
