Pragmatist
- Mar 30, 2025
@WiiM Support please take noteCan we have a toggle switch for the updated smarter Arc?
Hi pieterv1, team@WiiM Support please take note
Me, as well as a few others have no issues with how HDMI CEC/ARC currently works. It would be nice to be able to maintain the current behaviour in case the new implementation is causing issues with particular TV models or use cases.
Once it's pushed, client side still needs to seek it. The automatic seek function is probably not live, so it only does it periodically, with an unknown frequency/schedule. Manually checking for the update may reveal something pushed from server side that your client side did not yet automatically find.Not sure if this has been asked before (it may be a dumb question): if the new firmware updates are pushed by WiiM, apparently without user control, what's the point of the "check for updates" feature on the app?
Mr Nog,Once it's pushed, client side still needs to seek it. The automatic seek function is probably not live, so it only does it periodically, with an unknown frequency/schedule. Manually checking for the update may reveal something pushed from server side that your client side did not yet automatically find.
-Ed
Unfortunately not true in my case the last 2 updates were automatically downloaded and installed on my ultraIt doesn't get downloaded before you accept the update.
I extended my original post to cover that.Unfortunately not true in my case the last 2 updates were automatically downloaded and installed on my ultra
And the latest mini update was just installed without any input on my part
I'm never happy allowing software or firmware updates to be installed as soon as they have been released. I like to hang back and see how it affects other users. If it's good for everyone else then I will update.It doesn't get downloaded before you accept the update.
In certain cases critical firmware updates may be force pushed to th device, but this is not the standard case.
You'll have to take your own measures against this then.I'm never happy allowing software or firmware updates to be installed as soon as they have been released. I like to hang back and see how it affects other users. If it's good for everyone else then I will update.
I did, I blocked all Internet access for the Ultra in my router. That won't suit many people who use music streaming services but as pretty much all my content is on a plex server or a USB ssd within my home network it doesn't inconvenience me. I will unblock it when this firmware update is sorted properly. When Wiim have to pull an update because of bugs, I'm not exactly filled with confidence. But having worked in IT for many years, I realise that firmware and software updates are always a potential cause of problems and not being amongst the first to try them out is a good strategy.You'll have to take your own measures against this then.
As stated before, in most cases you are in full control on when and if to update your device.But having worked in IT for many years, I realise that firmware and software updates are always a potential cause of problems and not being amongst the first to try them out is a good strategy.
It's a bit tricky with a device like the WiiM streamers because there's also the client app. You'd want to keep both in sync or disable automatic updates on your phone as well.I'm never happy allowing software or firmware updates to be installed as soon as they have been released. I like to hang back and see how it affects other users. If it's good for everyone else then I will update.
I've only ever been able to delay an update for a short period by choosing 'Not now' at the prompt.in most cases you are in full control on when and if to update your device
I wonder what would happen if you unplugged it from the mains after delaying the update. Would it let you delay it again at the next power up?I've only ever been able to delay an update for a short period by choosing 'Not now' at the prompt.
e.g. I'll choose not now in the evening when I sit down for some listening, and by the next evening the update has been applied automatically.
Conversely, I find that 'Check for updates' very rarely finds anything.
Of course, it could all be in the timing, but I've been here for quite some time...!
My experience so far is that the 2 most recent Ultra updates were 'forced' on me without my specific request.As stated before, in most cases you are in full control on when and if to update your device.
An update being released (available for download if you chose so) and then withdrawn is simply not the typical case but an exception. Just as much as forced updates.
