WiiM Ultra
Status
Not open for further replies.
Updated on 5/25/2024
Updated on 4/19/2024
Hi Team,
Original message by Brantome:
Just confirming that "USB media server" means the Ultra will have a music server onboard and not need a separate computer running to support playback of local files? Just need to plug a portable USB drive into the rear panel of the Ultra. The server will support streaming to other WiiM players? Is it using DLNA/UPnP? Please make sure it is capable of "gapless" playback. Thanks.
Hi Apesbrain,
Yes, the 'USB media server' on the Ultra means it has an onboard music server, eliminating the need for a separate computer for local file playback. The USB media server is DLNA/UPnP compliant so you can use it with other DLNA/UPnP devices, including all WiiM devices. This feature is also available in our latest WiiM Amp.
Will the "Ultra" version be able to stream native DSD and ISO images either internally or out to an external DAC via USB?
Hi Apesbrain,
Can wiim ultra be use as preamp without loosing quality as the volume go down. I try the pro as preamp but to my ear it looses fidelity at low volume. Thanks!
The room correction EQ also applies to the USB output.
Yes, exactly.
This is quite excellent.
I suppose the important thing is that, after all this processing, delay can be set correctly so that the mains and sub are in synch.
I’m very much looking forward to this.
Thanks for the updates. I see it’s due for release in the second quarter of the year (April/May/June). Just be aware that my birthday is in April. ;)
What's point of phono stage? Those with high end system will use a dedicated phono stage. I wouldn't want a phono stage inside a audio streamer. And those with budget players have built in phono stage.
I would use the WiiM Ultra to replace as many Devices as possible (including a Phono Preamp).
I think that many people use older turntables that do not fall into the high-end category and do not have built-in Phono stages.
What's point of phono stage? Those with high end system will use a dedicated phono stage. I wouldn't want a phono stage inside an audio streamer. And those with budget players have built in phono stage.
I’m tempted to agree to some extent, but much of the vinyl revival defies logic.
There will certainly be people out there for whom this is a big plus, irrespective of my own thoughts and feelings.
Hi Steve, Team
Here are the upgraded features of the WiiM Ultra.
- USB out
- USB media server
- Sub out
- HDMI ARC
- Wi-Fi 6/BT LE audio
- A display
- Integrated power supply
- Phono input
I assume that the integrated power supply will be a SMPS. If so, i hope you will offer a DC input solution as well. Like Fiio did with their R7. It will make it easy to use an aftermarked linear power supply with the Wiim Ultra.
That would only add cost for a tiny niche of consumers with vivid imaginations. Makes zero sense.
it seems none of you understand that xlr is normally twice the voltage. for many higher powered amps 2V rca is not enough.
Please keep comments courteous - that could easily have been expressed better. Thanks
hello Steve,
What is the max delay that can be set ? I ask because i have a specific set of active speakers...
Thank you :)
hello Steve,
Thank you :)
The product is still in the design stage and I think the statement above was no more than a wish or an expectation, so there's no news of any of those details
Hi Steve, Team
- USB out
- USB media server
- Sub out
- HDMI ARC
- A display
- Phono input
Hello again @WiiM Support , I’m afraid I have another question.
In the past it’s been advised that users don’t use the volume control on your streamers, but set it to fixed output, then use something downstream (your amp/pre-amp) to control volume.
Clearly, with separate outputs for main speakers and a subwoofer, this wouldn’t be suitable, as the amp downstream would only adjust the volume of the mains, while the sub volume would remain constant - ditto if you were using the Ultra’s sub out and an off board DAC for the mains.
Will the ultra have some sort of pre-amp functionality where volume for both mains and sub are controlled together?
Many thanks.
thank you for your answer.
If a delay could be set, it would be a game changer (for me).
Could we just have a Pro with USB, coax and optical out, BT LDAC, RCA in, 12v trigger, upgraded chassis and components.
NO dac
No phono stage
No xkr
No sub out
No display
No volume control
No EQ
No hdmi
No 12s
So I don't have to pay for all that unnecessary stuff that my dac/preamp or Intergrated Amp dose.
Sure, just design and build one solely for yourself.
Exactly, they can't please everyone. I see their conundrum. They can try to design for the home theater and Sonos type croud or the audiophile crowd. I think it was quite an accomplishment to get the audiophile crowd interested in the fist place.
Status
