WiiM Ultra
Status
Not open for further replies.
Updated on 5/25/2024
Updated on 4/19/2024
Hi Team,
Original message by Brantome:
I think the elephant in the room is price. If the Ultra costs any where near 800 pounds then they will be shooting themselves in the foot. I believe many people just want a Pro plus with a USB output.
I think they want Pro Plus with HDMI ARC actually. The USB in/out is a niche use case by comparison.
Hm. XLR doesn’t have much to do with the price bracket, just with the *type* of gear you have. With XLR, all you’d need was a pair of (entry level, if you insist) Neumann or Genelec active monitors on top, and be happy for the rest of your days. Three devices. Ultra, left speaker, right speaker. :)
Wouldn‘t be surprised if there was an Ultra Pro on the horizon, with XLR.
Exactly! Or just AES dig out and no DAC at all (most of the modern actives perform D/A, no need for a DAC)
My opinions/interests do not matter in the grand scheme of things. I simply represent a fairly large number of WiiM customers who just want WiiM's excellent streamer with a clean USB out port.
Let us know once you have finally decided. :)
That means more boxes, so not exactly "exactly", right?
I promise I won't post to this thread until the Ultra hit the market because this discussion continues to be ridiculous.
Why not just use rca to xlr adapters?
Then you are still limited to 2Vrms meaning you have to up the gain on the amp or active speakers and increase noise/distortion. You also lose the advantage of balanced output in term of RF noise avoidance etc...
The DAC chip probably has a balanced output, I suspect the difficulty for WiiM was more around size/space at the back of the case. XLR connectors are big and the alternative Jack connectors are deep. Plus they would have wanted to keep RCA as an option for most users thus using even more space.
Yup. If you want to push me, maybe a coax input too.
Maybe 2 sub outs.
Maybe stereo PEQ/room correction, though I’d note the text of what we’ve said says ‘advanced room correction’, so who knows.
Maybe dedicated calibration mic to hook up to the USB input (still possible this will come with one, or be able to be upgraded to one).
And I’m really stretching now.
Yes, it's a pity there is no coax input!
Why is this an issue? I have devices that output at 150mv (0.15v) and my amps have no trouble getting them to 90+ db, just a bit further around the dial.
Some of those amps are only 20 watters.
A typical speaker of say 88db sensitivity is capable of outputting 88db at 1m distance with 1w of power. If you need 5v to output 1w, you have bigger issues than XLR.
As for the noise argument, the most basic amp in my collection, a technics su-v5, sports 0.005% THD+N at full volume, some of my better amps are capable of 0.003% or better. That noise is simply inaudible and irrelevant.
You misunderstood what I wrote, and I will not waste my time explaining, I don’t want you to accuse me of being more “ridiculous” :rolleyes: … time to close this thread again as folks just can’t seem to act like adults
Feeding a power amp with no volume control and an op amp input buffer with selectable gain. It measures better at lower gain settings :-)
That said the difference may well be inaudible...
Feeding a power amp with no volume control and an op amp input buffer with selectable gain. It measures better at lower gain settings :)
I'm sure you have far better measuring audio than my 0.003% THD+N, that said if you can hear distortion at a level of 0.003% you have far better ears than me, and that's with a 0.15v input. At 2v, I'm sure I can get much better measurements.
Is the Wiim ultra actually a pre-amp? I don't see any mention of this capability officially.
Define "pre-amp" :-)
It has multiple input sources, EQ and volume control, what else would a pre-amp do this doesn't?
Same with Pro & Pro Plus unless you need more inputs than it provides.
Define "pre-amp" :)
I would expect a pre-amp to have a separate volume stage that's not part of the streaming / dac stage. I notice that the Pro Plus has a noticable sound difference if I don't use it at 100% volume and use my amp to adjust the gain.
The pro plus has digital volume, that's probably the main difference. I tried using the volume control on my DAC instead of the WiiM but couldn't really hear a difference, that said I don't know if the topping D70 Pro uses analog or digital volume control.
Of course not. It’s a digital hub but no analog volume control. A digital volume control degrades the digital signal - essentially cuts down resolution (bits) as it ‘lowers’ the volume. Ok in a boombox. Unacceptable in a decent hi-fi system. To each his own.
Half volume, you lose one bit. 1/8th, you lose 3, out of 32 I think (the DAC internal resolution), or worst case out of 24. The 'loss' of resolution might be "unacceptable" on paper but isn't going to be audible in an output circuit :)
That said I'm the one arguing for balanced output which is also probably only an improvement on paper so... 🤣
Personally, I think phono preamp is looking backwards. Balanced/xlr is looking forward.
I would bet Linkplay will never offer a true analog balanced output. But time will tell. XLR sockets does not imply balanced… plenty of those and fooled customers.
That would be frankly weird and would show right away on measurements so I very much doubt it.
It also makes little sense economically since the bulk of the cost is going to be the connectors :) Those DACs can output balanced, so if you bite the bullet and put the connectors in, why would you fake it ? You wouldn't save anything.
For a fully analog device it's different, there is extra complexity in going balanced, but not here.
Status
