no just the internal Samsung micDidn't the imm6C calibration file have larger corrections at low frequency than that of the iMM6.
agreedIndeed![]()
Do any mics have internal active correction?Do these inexpensive mics have internal active correction (DSP)?
My B&K and PCB mics have smoother response, but still spec at similar ±1dB over similar frequency range. At >$1000 each.
I'd rather believe this is how it's accomplished so cheaply, and trust Dayton and MiniDSP--rather than believe their graphs are complete rubbish.
The internal Samsung mic doesn't have a calibration file at all but the file for the imm6C shows larger corrections at below 40Hz. It might not matter as.long as you don't try to correct below 40Hz.no just the internal Samsung mic
That's my assumption, based only on the name of one of the major sellers: MiniDSP. Micro electronics is a game-changer.Do any mics have internal active correction?
The MiniDSP audio processors use DSP, their microphones don't.That's my assumption, based only on the name of one of the major sellers: MiniDSP. Micro electronics is a game-changer.
There are reasons microphones with extended flat response sell for $1000 or more. If the IMM-6 and UMIK-1 can really equal that performance for $50 it would put the spendy ones out of business.
I doubt they're there yet...maybe soon they will be.
Then they're a miracle.The MiniDSP audio processors use DSP, their microphones don't.
You don't hear of many people using measurement mics for recording purposes. There must be a reason.Then they're a miracle.
Don't buy stock in Schoeps, Neumann, AKG, Shure, Sennheiser.
A story for you.. back in the early '70s I worked my way through college as a soundman for various local bands, and I also got rented out with the PA when out of town artists who didn't bring their own PA performed locally (it was pretty rare for the big country artists of that period to have their own PA so I ended up working for Marty Robbins, Buck Owens and others.)You don't hear of many people using measurement mics for recording purposes. There must be a reason.
The best bootlegs always seem to be made with Schoeps mics so presumably they are flat. Measurement mics don't really need to be flat over the the whole frequency range as long as they come with a calibration file.A story for you.. back in the early '70s I worked my way through college as a soundman for various local bands, and I also got rented out with the PA when out of town artists who didn't bring their own PA performed locally (it was pretty rare for the big country artists of that period to have their own PA so I ended up working for Marty Robbins, Buck Owens and others.)
I recall one night I suggested the lead singer of a local band I did a lot of work for try a different microphone as the one he used -- don't remember which model of Shure -- had a notoriously non-flat response. He about chewed my head off -- I was to use his preferred microphone and nothing else. The frequency response peaks and valleys of his mic were part of the sound he wanted when singing with the band. I suspect the same thing remains true in recording studios these days.
Absolutely no miracle at all. It's just so simple to make microphones with a somewhat extended and acceptably linear frequency response. There is absolutely no active correction in an iMM-6C or any similar mic.Then they're a miracle.
If it was, why would they go only halfway and still provide a calibration file for the remaining non-linearity?
You really are just making this stuff up. You do get individual correction for even a cheap iMM6 microphone. The calibration file is associated with the serial number and can be downloaded from the Dayton Audio website. If DSP was included inside a microphone you wouldn't need calibration files at all and even expensive measurement mics have them.Obviously you don't get individual, custom correction in a $79 microphone. You get a DSP programmed for the "typical" response of the mic capsule + an automated "calibration" that generates the correction factors for the UUT (unit under test).
I might be dead wrong here but this is a logical approach. Cheap micro electronics "fixes" so many things these days. Who would have imagined the micro transducers in our phones would sound so good? DSP ftw.
Exactly.I might be dead wrong here ...
FIFY... If individually customized DSP was included inside a microphone you wouldn't need calibration files at all and even expensive measurement mics have them.
Sorry no idea what FIFY meansFIFY
FIFY = Fixed it for you.Sorry no idea what FIFY means
Look fellow wiim user, many of us don’t understand that so if you don’t mind writing it completely.FIFY
Never said anything of the sort....
You told us more than once now that you own the best microphones money can buy. You are rich! I envy you. Go ahead, buy one, rip it apart and show us the DSP chip you found inside.
I don't assume anything. I'm an EE and i know.I assume they use cheap DSP chip to correct the major flaws, and supply a deviation sheet so the end user can correct the remaining error.
You two assume their mics are made of fairy dust and provide $1000 performance for $79.
