Ongoing Beta Beta Testing: Wireless Dolby 5.1 for WiiM Ultra
I'm using Dolby 5.1 (4.1 really) with two Audio pro A10s for the rears. I'm constantly having to change the audio delay in Plex for movies. It does not stay consistent. Is there any fix to this? I can get it almost sync'd to be passable, but never perfect. Apple TV 4k -> LG C1 -> WiiM Ultra
When I play PS5, the delay is very noticeable and I don't think the the PS5 has a sync option. What do I do for this case? Thanks
Immediately after reproducing the issue, it is recommended to submit a ticket via the feedback section of WiiM app. A log of the device will be sent to the team.
Are the "group audio delay" values consistent across all three WiiM devices?
Also, have you adjusted the lip-sync on either the TV or AppleTV?
If by group delay you mean the delay setting under the 5.1 menu, I’ve only set it there to the lowest value (70?). I haven’t done anything like that at an individual basis. The audio sync between the speaker group seem fine, I’m only concerned with the audio/video sync.
The only lip sync setting I’ve adjusted is the built in one on Plex for Apple TV that you can adjust on the fly. I have not adjusted the TVs or Apples settings.
I just hadn’t thought of submitting a bug report because the app made it seem like delay is inevitable, but that you could sync it.
Yes, that's it. I think it needs to be 70ms on all devices, but I don't know if the group audio delay can be adjusted if the A10 speaker is non WiiM Edition.
I'm not sure details, but if your PS5 is connected to a TV, you may need to adjust the lip sync or turn on game mode on the TV. Have you already tried those?
They are the WiiM Edition A10s. I figured setting the delay in the 5.1 menu under the ultra controls it for the entire group.
