But not if you use the tv remote while sending the signal over arc. At least for me - thats pretty annyoing adjusting the volume for the surrounds manually with every increase / decrease in volume for the fronts.However, using the WiiM remote control for the ultra in 4.0 surround mode, all 4 channels changes the volume at the same time.![]()
Hi Paffi, MusicianBut not if you use the tv remote while sending the signal over arc. At least for me - thats pretty annyoing adjusting the volume for the surrounds manually with every increase / decrease in volume for the fronts.
Yes.Sorry if this is a stupid question but will Wiim Ultra be able to simulate center speaker if have and use only 2+1 - left / rights / sub?
I thought that simulating a center speaker could help process the voices in movies better, making them clearer?Yes.
But needless to say, a single Ultra alone cannot play wireless Dolby. I don't think Ultra alone can do virtual 3.1ch playback at this time.
(I don't understand the intent of your question, so I will add to it.)
Hi sNc,I thought that simulating a center speaker could help process the voices in movies better, making them clearer?
Although it seems rather unlikely
Hi, Can I use Graphic EQ together with Room Correction results?Hi sNc,
In the Graphic EQ, there’s a "Spoken Word" preset designed to enhance dialogue in Movie Mode. Give it a try and let us know if it improves your experience!![]()
Not yet, although WiiM did say at one point they’d try to implement thatHi, Can I use Graphic EQ together with Room Correction results?
On that note, I noticed that recently a new support article was added by WiiM: Understanding the Differences and Relationship Between EQ and Room CorrectionNot yet, although WiiM did say at one point they’d try to implement that
Hi Team,On that note, I noticed that recently a new support article was added by WiiM: Understanding the Differences and Relationship Between EQ and Room Correction
In it they state the following:View attachment 18598
However as far as I can tell enabling PEQ still automatically disables GEQ (and vice-versa).
Is this article then an indication that this behavior will change soon?
@WiiM Team Could you perhaps clarify?
Hi Mr Ee,The obvious first question is which devices will support the beta?
I can see this making at least one person in particular very happy![]()
It mean 40-band PEQ is available?Hi Team,
Next week, we’ll be releasing a Beta firmware and app update that enables you to use Room Correction PEQ alongside your own GEQ or PEQ.
Stay tuned for the updates—exciting improvements are on the way!
Hi Wiimer,It mean 40-band PEQ is available?
Or can a stereo 10 band PEQ be overlaid on a 20 band RC? (30 bands total)
This is really great to hear!Hi Team,
I think the question was if the RC will be associated with the output settings as it should be.Hi dominikz,
Your understanding is mostly correct, with one exception - both GEQ and PEQ are available for input sound customization.
Thank you again for your valuable insights!
That also means speaker EQ separated from room EQ will be available!Hi dominikz,
