joentell
- Feb 9, 2024
Is that right? Does it work while it's in surround mode? If so, I will pin a comment with that correction.You CAN delay the surround speaker in the group setting on each device.
Yes !Is that right? Does it work while it's in surround mode? If so, I will pin a comment with that correction.
Hi Musician,
Please find our answers below:
1. Yes, you can use a single WiiM Pro for both stereo surround channels. The left channel will function as the surround left, and the right channel as the surround right.
2. We have addressed some noise issues reported by beta users. Currently, there are minor UI bugs in our app, which we plan to fix in the next update.
3. We are improving this feature. At the moment, you can use the TV remote or the WiiM Ultra (acting as the master device) to control the volume of the surround channels simultaneously.
4....
Update: I just saw your link to the previous post. Thank you.Yes !
Hi Musician,
4....
Look at WiiMs answer at 119#. I have tried it, works well![]()
They said, "You can adjust the audio delay by navigating to Device Settings > Sync Audio > Manual Sync. Gradually increase the delay to align the surround sound timing with the front speakers, ensuring all sound reaches your ears simultaneously."Update: I just saw your link to the previous post. Thank you.
It would be helpful if you tell me where to find the setting to add delay. I know there's a setting in you turn on the sub, but is there another place?
Are you talking about this? Because that's not nearly enough control over the delay to set it properly.
Yes, Amp and Amp pro do not have an audio sync section, so unfortunately that method does not work. For now, you can only do manual sync if you use Ultra as master.They said, "You can adjust the audio delay by navigating to Device Settings > Sync Audio > Manual Sync. Gradually increase the delay to align the surround sound timing with the front speakers, ensuring all sound reaches your ears simultaneously."
I'm seeing those options for device settings, sync audio or manual sync on the WiiM Amp or WiiM Amp Pro. Those settings are available on the Ultra and Mini I have.
The closest thing I see is the Subwoofer On > Syncing Subwoofer and Speakers > Manual Delay Adjustment.
So, it seems what I said in the video still holds true.Yes, Amp and Amp pro do not have an audio sync section, so unfortunately that method does not work. For now, you can only do manual sync if you use Ultra as master.
If you make the Amp pro the master, you can use the audio sync feature on the slave device side by making the Pro or Pro Plus the slave. (However, as I recall, this is not the recommended method and may not work well.)
Yes, only if you use a WiiM pro or pro+ as surround slaves, you can use delay for the surround channelsSo, it seems what I said in the video still holds true.
Hi 3Kie, TeamI'm using Amp Pro for front speakers and Mini for rear speakers - 5.1 doesn't work in this configuration.
@WiiM Team do you plan to add surround 5.1 slave (rear) funcionality to WiiM Mini?
Hi 3Kie, Team
We're exploring this option for the WiiM Mini; however, we haven't been able to support it due to its memory and CPU limitations. That said, our team is keeping it in mind, and if there are any updates, we'll share them with the community. Thank you!
Or some small (cheap) active WiiM enabled speakers that can be used as rear devices for the 5.1 setup.Firstly, well done for this feature. What an excellent idea.
Just to add a bit of realism, though.
It appears this requires an Amp Pro, or Ultra for the front (you'd have to add an amp to the Ultra, obviously). Then a Pro. Pro Plus or Ultra (plus amp) or Amp or Amp Pro for the rears.
I think probably the cheapest way in there is an Amp Pro for he front and a vanilla amp for the rears. But that's GB £750. That's simply not competitive with an AVR. I love WiiM, but if I were thinking about adding surround to my TV, there's no way I'd go down this route at this price. It's all a bit Heath Robinson bolt on.
Obviously, if you already have an Ultra or Amp Pro under your TV, you've got a head start. But if, like me, your WiiM hi-fi is elsewhere, but you love the WiiM ecosystem, and is looking for a way to add it to your TV, that's prohibitive.
So this is an idea, rather than a criticism. How about you release a Mini II with just a bit more grunt - enough to handle support to the front for this feature, and rear duties. Hey, let's push it a bit. Mini II with more grunt and a sub out. Now that'd sell well just as a streaming hi-fi front end. If that had been available, I may have bought it instead of the Ultra (though using an external DAC).
Phase out the old Mini. You've been brilliant at stretching its processing capabilities to their absolute limit, and it'd be nice to give your hard working development team a well-earned rest.
Imagine that. With 2 x £125 Mini IIs plus a couple of cheap amps (say Fosi Audio BT20Ds) you have set up for £430.
Indeed, make a WiiM version of the Fosi yourself, it has Bluetooth in, so you could by-pass the second Mini.
Yes, this is currently the cheapest--could go for cheaper still if possible: https://a.co/d/dz3dyhwOr some small (cheap) active WiiM enabled speakers that can be used as rear devices for the 5.1 setup.
They don't need to be so advanced. Just stripped down to the minimum for use as rear speakers.Yes, this is currently the cheapest--could go for cheaper still if possible: https://a.co/d/dz3dyhw
-Ed
The company itself is Swedish. I am not sure if their stuff is available in Denmark, but Sweden is closer to Denmark than it is to The United States ofThey don't need to be so advanced. Just stripped down to the minimum for use as rear speakers.
And then also available outside US.![]()
The WiiM versions of the Audio Pro is not available in EU. I can get it from US for $200 plus $114 in Shipping & Import Fees Deposit to Denmark. And I need two.The company itself is Swedish. I am not sure if their stuff is available in Denmark, but Sweden is closer to Denmark than it is to The United States ofAnarchyMAGAAmerica.
-Ed
Just out of curiosity: Why is the Mini's hardware too weak to handle two rear channels in a surround group while it is good enough to handle wireless stereo signals in multi room groups?Hi 3Kie, Team
As far as I understand the FAQ, the surround master performs all the 5.1 signal processing. So it would only need to send a simple stereo signal to the Mini. From the Mini's point of view it would not be any different to receiving stereo music in a classic multi room setup.
But I probably overlooked something. What is it?
Hi Steve, TeamFirstly, well done for this feature. What an excellent idea.
Yes, this is exactly the way I do it in my setup and it works like a charm. This way, there is also 10 band PEQ for all four channels ( two in Ultra and two in pro ) and also the possibility to delay the surround speakers . I use ethernet for my Ultra and wifi for the pro.Hi Steve, Team
Currently, you can set up a wireless surround system by pairing one WiiM Ultra with one WiiM Pro. The WiiM Pro supports left and right surround channels, allowing you to connect bookshelf speakers with RCA or optical input.
I hope this setup works for you - let me know if you have any questions!
