hellyeahdude
- Aug 18, 2024
How much the sound improved, in percents?These gel feet lifted the wiim from my furniture, decent upgrade.View attachment 10643
Why, night and day, of course! LolHow much the sound improved, in percents?
does it have any sonic benefits tho?Every now and then its advisable to use a clean cloth and wipe away the dust on your device.. Actually daily would be better..![]()
1. Dust and dirt is one of the most well known enemies of all electronic devices. A clean device will perform better and last longer.does it have any sonic benefits tho?
2. It will also look better on the pic..![]()
Lmao. Best answer everPlacing a banana on either side of the wiim will improve sound too.
Under no circumstances use one banana as the intermingled flux of potassium will create intermodulated channel distortion on the other channel. For ideal performance use two bananas. Also use calibrated calipers to get the distance of the bananas to the wiim correct.
Honestly. I think people that post things like this aren’t serious. Guessing only thoughPlacing a banana on either side of the wiim will improve sound too.
its serious and you should try it before assuming thatHonestly. I think people that post things like this aren’t serious. Guessing only though
If dust settles. Make sure it’s audiophile quality dust.does it have any sonic benefits tho?
Dude come on. Really? From a looks standpoint….sure. Audio improvement? Maybe if you have Superman levels of hearingt
you know we also hear with our eyesDude come on. Really? From a looks standpoint….sure. Audio improvement? Maybe if you have Superman levels of hearing
Like I said. From a visual prospective sure.you know we also hear with our eyes
Lmao. Love thatLess expensive: Cut 2 squash balls (black) in half and attach with double-sided adhesive tape. Even more airy and more transparency in the room. Tell female visitors and, as a sporty guy, point out that you came up with the idea during the last final. Good luck![]()
The bananas?t
