I presume they are using a new beta release of Tidal, with native flac's until 192khz.So you’re getting 24/196? I’m only getting 24/96 on tidal connect. I can set it to 24/196 but according to DAC it’s only outputting 24/96. The wiim app also reports 24/96.
I tried turning off MQA but then only can streams at 24/48.
I'm waiting for this new Tidal's tier, since I like its app, better than Qobuz one and in some aspects even better than Spotify that anyway, should be taken as reference for connection and suggestion partsPolite to name it miracle, I name it hoax
In the meantime I think that the talk is about Tidal's new high res tier, no longer the dead horse MQA.
As you added.
And it cannot be even verified as the final unfold must be involved with a DA conversion...The upsampling secret mqa post processing, claims itself to be better than any other system, even compared to native 192khz flac version of same mastering.
Speaking with an MQA enthusiast studio guy, he had to admit that the "master" tag is part of a process that no one can assure has always taken place.And it cannot be even verified as the final unfold must be involved with a DA conversion...
This is it.I presume they are using a new beta release of Tidal, with native flac's until 192khz.
MQA files are delivered 44.1/16bit and 48/24. First unfolding by enabled WiiM's or any mqa dac, produces respectively 88.2/24 and 96/24. Any other higher resolution, is done by external dac's mqa "miracle" upsampling.
So, if you use just mqa enabled WiiM's, is normal to get until 96 only.
Do you mention the PC app here? I have constant issues with Tidal Connect discovery when using their PC app.I'm waiting for this new Tidal's tier, since I like its app, better than Qobuz one and in some aspects even better than Spotify that anyway, should be taken as reference for connection and suggestion parts
Mainly I use android and ios apps, just very seldom I use the pc app but I don’t recall particular problems, statistically has no value...Do you mention the PC app here? I have constant issues with Tidal Connect discovery when using their PC app.
Yes using the new beta of tidal. It’s suppose to support the new 24/196 flac files tidal is moving too. I have it set to max output that suppose to be 24/196. Using the wiim pro the highest I’m able to get is 24/96.I presume they are using a new beta release of Tidal, with native flac's until 192khz.
If I remind well, in Qobuz, the 192khz files were not too many, majority was 96khz. Could files you are listening to, originally at 96KHz?Yes using the new beta of tidal. It’s suppose to support the new 24/196 flac files tidal is moving too. I have it set to max output that suppose to be 24/196. Using the wiim pro the highest I’m able to get is 24/96.
Guess wondering if anyone else using the tidal beta is getting the 24/196? Trying to determine if it’s something wiim needs to change or if it’s something on my end.
