Home Music Share keeps skipping to next track
Xidnpnlss
Hello good people.
When using the Wiim iOS app to stream FLAC from my external hard drive it’s been skipping randomly to the next track. I’ve been trying to pay attention to anything going on on my phone or whatever to see if there’s something that’s triggering it, but it seems very random. I only occasionally use it to stream so can’t be sure if it started doing this after an app update
Any thoughts? Thanks in advance.
No, I'm not using DLNA on the computer (those servers are listed under "Media Server" in the app). I'm trying to use SMB folder sharing ("Shared folder" in the app).
Any particular reason? I always see SMB as a last ditch solution when much better solutions like Minimserver are available.
Might it be a permissions issue at the file level?
That component was abandoned years ago so I wouldn't recommend it to new users.
...why not? Do not allow Internet access (can be set under Server) and everything is OK. Just because it's a bit older doesn't mean it's bad. A very reliable and secure solution, even for Windows 11, and unlike MinimServer, without Java.
...why not?
Primarily because it's not supported, but I seem to remember issues with track numbering and album sorting (not a natural sort) too.
I use foobar but it's not really a user friendly tool, but I take your point about Java and MinimServer which is why I run my Windows instance in Sandboxie Plus.
...I have no problems in this respect. What is really a bit poor, however, is the search function. It should just be a suggestion instead to the windows own programs. I mainly use MinimServer (still 0.8.5.2) on my QNAP NAS only in my own network, I prevent Internet access in the router settings 😉
Given MinimServer relies on UPnP I don't understand how it could work across broadcast domains, unless QNAP has its own tools to do so.
I tend to use Tailscale for remote access, although I've just moved to an OpenSubsonic solution which has great offline functionality so I don't have the need so much now.
OK, maybe my bad English 😉 I prevent access to the entire NAS by disabling internet access in the router as I don't need remote access. QNAP once had problems with a piece of firmware, which led to various hacker attacks for some users.
I'm using the same network user account on all devices, so normally the permissions should be the same.
The Wiim skips all the files as if they can be accessed, but are unplayable. The same files play on all other devices, over the same network share.
Have you tried copying one of the skipped files to your phone to check that it plays from there (WHA > My Music > Local)?
EDIT: I'm not able to test JetAudio+ as it doesn't offer a trial, but one thing you should know is that WiiM doesn't index SMB shares, it only offers folder/filename browsing, so as has been suggested a server offers a much richer browsing experience.
I wonder if there are authorization problems here and if the Windows firewall needs to be configured.
Just for information: I also use Symfonium on Android with SMB access to my Qnap NAS music library. FLACs and mp3s are played flawlessly on the Ultra, Pro and Mini.
As I understand it, an attempt is being made to access with the WHA via SMB. It is quite possible that the permissions are “you can look but not touch” (figuratively speaking, it's been years since I dealt with this 🙃)
So not firewall/authentication but filesystem permissions perhaps. I did wonder that initially, but given other apps work - with the same access - I wouldn't have thought that could be the case.
Thanks. The file permissions are set to "Full control", and the access works with my Android devices using the same account.
Maybe activated SMB1 in Windows during testing? Some applications react sensitively to this because SMB1 is not secure and deny access.
After right-clicking on the start button, select "Windows PowerShell (Administrator)" to start Powershell.
To deactivate SMB 1, enter the following command and confirm it with the Enter key: "Disable-WindowsOptionalFeature -Online -FeatureName smb1protocol"
After deactivating SMB 1, the computer must be restarted.
See also:
OK, these are the last things I can think of:
- Has the WiiM app been set up properly for access? Instructions:
- as discussed at the beginning: Is the correct user really entered in the WiiM app? It actually looks like user rights are missing here. Sometimes you have inadvertently set a tick or dot at the end of the user name without realizing it. If necessary, simply reset all entries in the WiiM app and fill it out again
- Finally, not absolutely necessary but nevertheless, I recommend installing the Windows 10 Firewall Control Free (also runs under WIN11) to see in real time or simplified if there are any restrictions. Here you can also monitor services and grant/deny access:
Good Luck!
@ClaudeJazz
Have you tried the above yet?
Alternatively, use the BubbleUPnP Android app (assuming JetAudio can't cast to the WiiM) to browse your share and play to WiiM. This will remove SMB from the equation (for WiiM) and check file compatibility.
Hello. I have had this problem and have traced it to files having very long names due to the tracks having long, descriptive titles. In order to make the affected files play without any skipping I have been manually shortening the track names after downloading and prior to copying the files into my Music Folder (which I keep on a separate, USB-connected external hard drive for capacity reasons). Generally I don't have to shorten them all that much; it solves the problem, but it is a royal pain to have to do this. There seems to be some kind of limit on the length of a file name in order for the system to handle and recognize it. I have started a ticket about this to see what can be done about it; however, it is interesting to note that when trying to delete a downloaded file or album containing unshortened files with these long names after copying it to my Music Folder (and a backup USB drive), I receive a message saying the file is too long to move to my Recycle Bin, and asking me if I want to bypass this step and delete it directly. This happens only with the albums having long files that have to be shortened to play properly. From this, I suspect the problem has to do with Windows (I have Windows 11) and/or Windows Media Sharing, and not with the WiiM app or devices. I am waiting for an answer from WiiM.
Windows Media Sharing orders the tracks of multi-disc albums alphabetically, so it's probably worth trying MinimServer to see if it's just another WMS issue - although I would recommended shorter filenames (I use %discnumber%.%tracknumber%).
