Is your producing noise? I have mine volume set 100 and fixed volume I don’t hear cracking, distortion or noise after rc.I was lost in the noise. Is the automatic curve saveable like a manual curve?
Sorry, I meant I didn’t see or understand the post about editing the automatic curve. Too many conflicting posts.Is your producing noise? I have mine volume set 100 and fixed volume I don’t hear cracking, distortion or noise after rc.
For case #1, I understand, two WiiM's are serially connected. WiiM A (first unit, upstream) is the receiver of the stream and sends fixed volume output to WiiM B (second unit, downstream) via toslink. If everything works, you'd like to do RC on WiiM A first and adjust volume limit to avoid clipping. If it works, you'd like to do RC on WiiM B while WiiM A is doing RC. I assume RC parameters are identical between WiiM A and B (target curve, frequency range, max gain and Q). Alternatively, do you want to divide RC frequency into two bands - i.e., WiiM A covers low frequency and WiiM B for high frequency.Is there anyone out there who is running a (silly) RC experiment using two WiiMs?
1. two WiiMs are connected in series with optical cables, and RC is performed on each WiiM. I am interested in what happens to the RC results on the upstream WiiM B after correction on the downstream WiiM A.
2. two WiiMs in parallel, WiiM A to the right speaker and WiiM B to the left speaker; perform RC on the right speaker with WiiM A and on the left speaker with WiiM B. Play A and B as a stereo pair on the MRM.
Is there anyone else brave enough in their spare time who would like to try these things besides me?![]()
For case #2, I would not know what network jitters will do. For better understanding of RC, I would do hard left and hard right panning for RC measurement and see if there are significant difference.
If I were willing to have another WiiM just to refine RC, I rather buy a dedicated and much more capable RC hardware solution such as IK Multimedia Arc4 ($300, including measurement microphone).
The frequency response is known and compensated for.Unless the srequency response of the microphone in your device is known and compensated for then this RC feature seems pointless.
They’re more likely to tackle the wide range of Android devices by focussing on a smaller range of external micsAndroid has a lot of hardware and everyone is different. Maybe they will, but only for a few of the most popular devices.
We will have to wait and see for Android. For external mics calibration files will need to be accepted.Android has a lot of hardware and everyone is different. Maybe they will, but only for a few of the most popular devices.
in earlier days I had to record environmental noises for official purposes. Governmental organizations accepted recordings with an iphone (they tested its performance and accuracy). This is not common! So i stick with the iphone…Just for curiosity. Is there any difference (or preference) with the mics in iPad or iPhone?
There is no noise. The automatic curve can be saved, adapted, saved again - also with a different name, compared again… Your choice!I was lost in the noise. Is the automatic curve saveable like a manual curve?
The curves looked weird to me too. At lesst in the beginning. But as others explained too, this could be ok and should be ok if it sounds right. The point is, the corrections can be very detailed; look at the Q value - the higher it is the narrower the correction.Just ran room correction, it does sound a lot better and opened up the sound stage significantly. Does anything look weird/ concerning about these adjustments though?View attachment 8280
Easier just to borrow an iPhone.They could make a mandatory to attach external mic so even the least expensive tablet can use rc on android.
What if there’s no iPhone to borrow or they won’t let you?Easier just to borrow an iPhone.
Amazon sells iPads for $125. I have a sound meter that works on both phone and tablet. You’d have to ask Wiim if this is true of their app. This seems like a lot less trouble than buying a calibrated mic that isn’t calibrated for the Wiim.What if there’s no iPhone to borrow or they won’t let you?
