In Subwoofer Bypass Mode
TSHRED
Active member
Does the crossover point still apply to the main speakers?
I want to try my sub's built in crossover.
Yes even though the crossover becomes greyed out it does high pass the main speakers.
Thanks, one more question.
If I use the switch at the top and shut the subwoofer management off does it automatically default to full range to the mains?
Yes, if the subwoofer setting is off, WiiM does nothing to the main speakers and sub. Therefore, no sound comes out of the sub, and the mains revert to full range output.
Thanks.View attachment 12944
The sub bypass is one of the best feature and you will feel your how your sub really sound. When off, it was loose and boomy. When on, tight and controlled. It also does high pass when enable. If you want double whammy bass you enable both switch. Sub and main both produce bass.
We already have that don't we. That is exactly what we are talking about.
I not sure if he mean separate setting for high and low much like minidsp. It would even great if included different filter and slope like butterworth, linkwitz and others. Minidsp has so much to tweak for advanced users.
What I would like is an active and adjustable hi-pass filter that I could adjust when the unit is in Subwoofer Bypass Mode.
It can still be done but not convenient. Turn off sub bypass then adjust to your desire then enable. The set frequency is where the high will go. We as user like easy and can be nitpicking on anything.
Can someone please help me. I have a svs sb 2000 pro subwoofer. Id like to use the build in svs app feature instead of the wiim ultra bass management. What do i have to do for this? Enabe bypass mode and thats it?
Thanks in advance!
Well, almost.
You have to make sure to manually configure the SVS app, of course. Matching the crossover frequency and slope. And adjusting the phase (unless the SVS app can do that automatically).
