- Sep 23, 2024
We're excited to announce that we're bringing the WiiM OS with all its functionality and features to Audio Pro speakers with the A10 MKII WiiM Edition and C10 MKII WiiM Edition. Experience the power of the WiiM OS driving these speakers to new heights starting Oct 2024.
The A10 MKII is perfect for small spaces, with its compact design and 50-watt output, while the C10 MKII is ideal for larger rooms, featuring an 80-watt sound system with a 5.25" woofer and two textile dome tweeters. Both speakers deliver exceptional sound quality, and we've now optimized these speakers for WiiM OS, they're now smarter than ever!
Bringing the Power of WiiM Home OS to Audio Pro
Our innovative WiiM Home OS is at the heart of the WiiM products you know already, and these new smart speakers are powered by those same smarts, providing a seamless and intuitive user experience. With the WiiM Home App, you can effortlessly manage your music, podcasts, audiobooks, and internet radio from one central place. Manage all your music and devices from one place, making it easy to switch between your favorite music services like Spotify, Amazon Music, TIDAL, Deezer, Qobuz, and your personal music library. Plus, you can control all your WiiM-compatible devices with just a few taps.
Seamless Casting, Every Time
We've made sure that WiiM OS on the Audio Pro A10 MKII and C10 MKII plays nicely with all your favorite casting services, including Apple AirPlay, Google Chromecast, DLNA, Spotify Connect, and TIDAL Connect. That means you can stream your music from any device, without any hassle, and enjoy the highest sound quality.
Immersive Listening, No Interruptions
Our gapless playback feature supports up to 24-bit/192 kHz audio quality, so you can enjoy your music without any interruptions. Whether you're streaming a full album or a curated playlist, the music just keeps flowing.
Connect Your Way
WiiM OS is all about flexibility. You can connect your turntable, TV, or stereo system, and enjoy your music the way you want to. We've also included built-in support for voice assistants like Google Assistant, and Siri, so you can control your music hands-free.
Sound Shaped by You (and Your Room!)
We know that every room is different, which is why we've developed our patent-pending automatic room correction feature. This clever tech adjusts the sound to fit your space, so you get the best possible listening experience. Plus, you can fine-tune the sound to your liking with our extensive EQ customization options. And, with our advanced bass management feature, you can get the perfect balance of bass and treble.
Always Up-to-Date
We're committed to keeping your WiiM OS up-to-date with the latest features and improvements. That means you'll get regular firmware updates, new features, and expanded compatibility with the latest music services. Your music experience will always be fresh and exciting!
What You Can Expect
The A10 MKII WiiM Edition and C10 MKII WiiM Edition speakers are designed to provide a seamless listening experience. They’ll integrate with existing WiiM devices and be controlled with the same app, allowing for synchronous playback. With the WiiM Edition of these speakers you can:
Continuous Innovation
At WiiM, we're committed to continuously refining your audio experience. Our regular firmware updates ensure that you'll always have access to the latest features, music services, and enhanced audio quality.
Experience the Future of Smart Speaker Technology Today
Discover the perfect blend of innovative technology and exceptional sound quality with the AudioPro A10 MKII WiiM Edition and C10 MKII WiiM Edition. Upgrade your home entertainment experience with WiiM Home OS and enjoy unparalleled music control and customization.
C10 MKII WiiM Edition and A10 MKII WiiM Edition Specifications Comparison Chart
Find them on Amazon Audio Pro A10 MKII WiiM Edition and Audio Pro C10 MKII WiiM Edition.
Connect Your Way
Always Up-to-Date
What You Can Expect
- Stream music from your favorite services, like Spotify, Amazon Music, Deezer, Qobuz, TIDAL, and many more including your own music library.
- Control your speakers with your voice using Google Assistant, and Siri
- Customize your sound with our intuitive EQ settings
- Enjoy high-quality audio with gapless playback and streaming up to 24-bit/192 kHz
| Feature | A10 MKII WiiM Edition | C10 MKII WiiM Edition |
| Type | Powered speaker with dual low frequency radiators | Powered stereo speaker with bass reflex |
| Colors | Dark Gray | Black |
| Amplifier | Digital Class D, 52 W | Digital Class D, 2x20W + 40W |
| Tweeter | 1 x 1.25" BMR | 2 x ¾” textile dome tweeter |
| Woofer | 1 x 3" long throw | 1 x 5.25” |
| Low frequency radiators | 2 x 4.5" | - |
| Frequency Range | 55–20.000 Hz | 45–22.000Hz |
| Crossover | 300 Hz | 2.500Hz |
| Audio Input | WiFi, Bluetooth 5.0, 3.5 mm | WiFi, Bluetooth 5.0, RCA |
| Audio Output Connections | - | Sub output |
| EQ Options | Independent EQ settings, 24 preset EQ settings, 10-band graphic and parametric EQ, Automatic room correction | Independent EQ settings, 24 preset EQ settings, 10-band graphic and parametric EQ, Automatic room correction |
| Streaming Support | AirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Coming Soon) | AirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Coming Soon) |
| Multi-room | WiiM, AirPlay, Chromecast Audio | WiiM, AirPlay, Chromecast Audio |
| Stereo Pairing | Yes | Yes |
| Connectivity & Power | 100-240V AC input, Wi-Fi 5, Bluetooth 5.0 | 100-240V AC input, Wi-Fi 5, Bluetooth 5.0 |
| Dimensions | 193 x 140 x 140 mm | 166 x 320 x 180 mm |
| Weight | 3.3 lbs (1.5 kg) | 8.6 lbs (3.9 kg) |
| Physical Buttons | Power/standby, Source switch, 4 preset buttons, Play/Pause, volume, reset, Bluetooth pairing | Power/standby, Source switch, 6 preset buttons, Play/Pause, volume, reset, Bluetooth pairing |
| LED Indicators | 3 white LEDs for status, 10 white LEDs for volume indication | 3 white LEDs for status |
| Power Consumption | 1.8 W-0.3 W-3 W | 1.7 W/<0.5 W/6.2 W |
| Wall Bracket Insert Nut | M6 | - |
| Price & Availability | $229, Oct 2024 | $399, Oct 2024 |
