- Oct 19, 2022
Hi WiiM Community,
We are excited to introduce the WiiM Amp Pro, the next evolution in streaming amplifiers, designed for audiophiles and home entertainment enthusiasts. With advanced Post Filter Feedback (PFFB) technology, this amplifier guarantees high-performance sound regardless of speaker load, elevating your audio experience. It features the latest Wi-Fi 6E and Bluetooth 5.3 (with BT LE audio support) for seamless, stable, and high-fidelity streaming, perfect for any hi-res audio streaming demands.
Whether you're connecting classic passive speakers, a home theater setup, or a vintage record player, the WiiM Amp Pro offers exceptional integration options. Control everything through the WiiM Home App, play music from top services like Spotify, Amazon Music, or stream from your favorite app. Plus, enjoy hands-free operation with Alexa and Google Assistant for the ultimate convenience.
Key Features:
- Powerful Amplification: 60W per channel at 8 ohms, or 120W per channel at 4 ohms, capable of powering up to four speakers.
- Top-tier Audio Components: 32-bit/384kHz ES9038 Q2M SABRE DAC and TI TPA3255 Class-D amplifier.
- Wireless Connectivity: Dual antennas with Wi-Fi 6E and Bluetooth 5.3 for rock-solid streaming.
- Elegant Design: Encased in an award-winning aluminum body for a premium, modern look.
- Room Correction: Automatically tailors sound to your space with precise acoustic measurements.
- Superior Sound Quality: Delivers exceptional clarity with -105 dB THD+N and 120 dB SNR at 5W.
- Advanced Thermal Design: Designed with an innovative thermal management system that includes copper, aluminum, and graphene heat sinks, ensuring reliable performance even in the most demanding conditions.
- Seamless App Control: Access a broad range of music services via the WiiM Home App.
- Gapless Playback: Enjoy uninterrupted, high-resolution playback up to 24-bit/192kHz.
- Versatile Input/Output Options: Easily connect external devices, from turntables to TVs, with HDMI ARC, Optical, and RCA inputs.
- Subwoofer Output & HDMI ARC: Ideal for creating a complete home theater setup.
- Dolby Digital Support: Enhance your home cinema experience with Dolby Digital decoding for immersive surround sound.
- Voice Control: Hands-free operation via Alexa and Google Assistant, with voice commands.
- Please Note: AirPlay is not supported, and the device cannot function as an AirPlay receiver.
Tech Specs:
- Amplifier: Class-D, 60W/channel (8 ohms), 120W/channel (4 ohms).
- Audio Input: Analog (RCA), Optical, HDMI ARC, supporting up to 24-bit/192 kHz.
- Audio Output: Up to 192 kHz/24-bit, adjustable EQ with independent settings for each input.
- Connectivity: Wi-Fi 6E, Bluetooth 5.3, Ethernet, USB Audio Out, USB Media Library support.
- Physical: Compact size (7.5 x 7.5 x 2.4 inches), weight of 4.1 lbs, aluminum case.
- Accessories Included: WiiM Voice Remote, HDMI cable, RCA, optical audio cables.
- Price: $379 USD. It will be first available in the US on Amazon (starting 9/25) and through other US distributors, with international availability next month.
