Introducing WiiM Sub Pro: Experience Bass Like Never Before
🔥 WiiM expands into deeper sound! Meet WiiM Sub Pro, our first-ever subwoofer, designed from the ground up to deliver deep, distortion-free bass with AI-driven precision. Whether tuning your music, movies, or gaming setup, this sleek sub delivers precision through its 8-inch driver and Class-D amplifier, boasting a frequency range of 25Hz–200Hz which adapts to your space for optimized performance.
After years of perfecting streaming and amplification, we listened to our community and built a subwoofer that enhances your audio setup with clean, powerful bass and seamless wireless connectivity.
AD_4nXfYN4BgslKzRUjXM6VFt6p0Fc6uHIGOsa87gMd-OkdMA1hWqWeszI_RlVaUs281-laCb386CGUYJBa7aSAHmPcg1GYJw1MYEkKDuBD4sgn9i3TExHCNxi6-GcelqgzUgMBqSEwr
What makes WiiM Sub Pro stand out?​
  • Reliable wireless connectivity: Supports Wi-Fi 6E, 802.11 b/g/n/ac/ax 2.4 GHz, 5 GHz, and 6 GHz., Bluetooth 5.3 and RCA input enabling seamless connection to a wide range of audio setups.
  • Smart power management: Automatically enters standby mode and detects RCA signal or plug input to optimize energy use and simplify daily operation.
  • Precision sound enhancement: Includes Auto Room Correction for both the main speaker and subwoofer, ensuring optimized bass performance based on your room’s acoustics.
  • Flexibility of WiiM connectivity: Connect the Sub Pro with any WiiM streamer, amplifier, or speaker!
Seamless Integration with WiiM & Third-Party Devices​
Works flawlessly with WiiM streamers, amps, and speakers for tight bass performance. Pair WiiM Sub Pro with WiiM Sound, or enhance your existing WiiM setup for deeper bass and dynamic home audio. Have a WiiM streamer or amplifier without a subwoofer output? The WiiM Sub Pro can sync with them wirelessly to bring room filling sound to your setup!
Supports third-party devices via analog RCA mono input.
Key Features:​
  1. Powerful & Distortion-Free Bass
    1. 250W of deep, clean bass with less than 1% THD+N, delivering an immersive experience for movies, music, and gaming.
  2. AI-Driven Room Calibration for Precision Bass
    1. RoomFitâ„¢ Auto-Calibration takes precise acoustic measurements, adjusting bass to match your room size, speaker placement, and listening position.
  3. Next-Gen Wireless Connectivity
    1. Wi-Fi 6E for a low-latency, high-bandwidth connection, ensuring stable and interference-free performance.
    2. Bluetooth 5.3 with LE Audio for flexible connectivity with supported devices.
  4. Advanced App Control for Custom Sound Tuning
    1. The WiiM Home App allows for precise EQ adjustments, crossover tuning, phase control, latency customization, and subwoofer level adjustments.
  5. Elegant, Acoustic-Optimized Design
    1. Premium cabinet construction with custom-designed woofers, engineered for vibration-free, resonance-free bass even at high volumes.
    2. Sleek, modern aesthetics that blend effortlessly into any home décor.
  6. Seamless Integration with WiiM & Third-Party Systems
    1. Designed to work flawlessly with WiiM streamers, amplifiers, and speakers for a cohesive audio ecosystem.
    2. Connects easily with third-party devices featuring a subwoofer output, ensuring broad compatibility.
  7. Always Improving with Firmware Updates
    1. Regular over-the-air updates introduce new features, enhancements, and performance optimizations, keeping your system at the cutting edge.
Tech Specs​
🔊 Speaker: 8-inch driver | 25-200 Hz range | 104 dB SPL sensitivity
🔌 Connectivity: Wi-Fi 6E | Bluetooth 5.3 | Ethernet | RCA input
🎚 Subwoofer Control: Adjustable crossover frequency, level, phase, and latency
🎛 EQ: 10-band parametric EQ + automatic room correction
Dimension: 15.7 x 11.8 x 12.7 inches (399 x 301 x 322 mm).
Weight: 35.2 lbs (16 kg).
Pricing & Availability​
WiiM Sub Pro launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
🎶 Ready to feel the difference? Let us know how you'd use WiiM Sub Pro in your setup!
There are also some of us who prefer to cut the crossover higher than 80Hz, especially those of us with standmounts instead of full floorstanders; in those scenarios, we definitely want stereo subs, one at the base of each speaker and crossed over in the 100-160Hz range.
-Ed
-Ed
These discussions question a lot the brutality or not of the filtering slopes, the impact in phase etc.
So I assume, it can play perfectly in sync with a Ultra connected to its own poweramp & speakers?
But how to determine if I really need this... 😅
My Lintons have 8 inch drivers and a lot of oomph already.
:censored:
(there is already a strong bias there... more classic with small 2voices..)
invites you to observe a piano playing with a lot of energy at 42Hz "fa" and to observe its harmonic structure... ;-) and this is only talking about a single note... imagine a chord of low notes etc...
Most of those harmonics will not be handled by the sub. Not sure what point you are making.
f1 f2 f3 f4 depending on the choices and slopes adopted will be...
Don't forget that the first harmonic (see the second and third) are generally very high...
piano at left...sub at right? ;-)
Again, it is a question of use-case and priorities.
For me personally bass without resonances and nulls trumps any potential spatial effects in low bass, but people are free to feel differently. :)
certainly...
but my point in reaction to the eternal ..."""we don't care the bass is omni..."""" ....
and the reasoning shortcuts or lack of understanding that follow in many...
Also bass below 80Hz or so is normally mixed as mono even for recordings of pianos 🙂
certainly...
Please notice that I didn't make any such claim in my posts. :)
Yes, I suspect there aren't that many recordings with appreciable stereo content below 80Hz
but 80hz..it's very high.... hihi in acoustic music from like 27/28hz it's good to consider a certain spatialization that exists in real life.. see large symphony orchestra etc..... ;-)
Sorry, but I have a feeling that you and I are not talking about the same thing.
I only said that I don't believe many commercial recordings have significant stereo content below 80Hz.
Whether or nor they *should* contain it is a different topic that I would like to avoid discussing here. 😜
Key Features:​
Tech Specs​
I am wondering if there are screw holes for wall mounting or not... 🤔
Edit;
This is a question for WiiM Sound...
in this it is well attached to cultural approaches, "expertise", in the sense of cognitive sciences and not to """" audibility thresholds in the general population""""
"""""Something tells me you have a nose? But you think you smell like a professional perfumer's nose?
And worse, the subject of music is even more complicated ;-)
