Introducing WiiM Sound Lite: Hi-Res Audio in a Minimalist Design
📢Expanding the WiiM family! WiiM Sound Lite, our newest smart speaker, is here! The WiiM Sound Lite delivers studio-grade sound, seamless connectivity, and whole-home expandability in a sleek, display-free design.
Along with the newly launched WiiM Sound, we've created Sound Lite for music lovers who want powerful, room-filling Hi-Res audio without a touchscreen display. With 24-bit/192 kHz playback, AI RoomFitâ„¢ room correction, and versatile EQ customization, this minimalist speaker adapts to any space and any listening preference.
Why WiiM Sound Lite?​
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Presets and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with advanced EQ tools including 10-band graphic and parametric EQ for precise adjustments.
  • AI RoomFitâ„¢: Actively takes precise acoustic measurements of your room, crafting customized corrections for optimized audio.
  • Stereo pairing: Seamlessly pair two WiiM Sound Lite speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Google Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, Alexa Cast, or Roon (certification in process).
Powerful, Flexible, and Customizable Sound​
Whether placed on a shelf, counter, nightstand, or wall-mounted, WiiM Sound Lite seamlessly blends into any space while filling it with studio-quality audio.
✅ 100W peak power delivered through a 4" long-throw woofer and dual 1" silk-dome tweeters
✅ Automatic room correction for personalized acoustics
✅ Stereo pairing - connect two for a true left/right speaker setup
✅ Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
Hi-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Google Cast, Alexa Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA
🎤 Control with Alexa or Google Assistant (via compatible devices). WiiM Voice Remote 2 Lite available separately for one-press control.
Smart Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including 10-band graphic & parametric EQ and input-specific adjustments.
🎭 Home Theater ready, use WiiM Sound Lite as surround or center speakers in a Dolby 5.1 setup with compatible WiiM devices.
🖼 Minimalist, display-free design with a clean, modern look that fits effortlessly into any room.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs​
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LC3) | Ethernet | 3.5mm Aux
Sound Performance: 50 Hz - 20 kHz, 100W peak output
Streaming Platforms: Google Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, LMS, Roon Ready
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7" x 5.7" x 7.5" (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound Lite launches December 25th, 2025 on Amazon (US) in white and black for £229 / $229 / AU$399 / €269. Full details at www.wiimhome.com.
Note: The WiiM Voice Remote 2 Lite is not bundled but is fully compatible for users who prefer one-press or push-to-talk control.
Yes, there are alternatives, and I currently have my own.
But we're talking quality, and integration into the WiiM infrastructure here.
On other similar threads I have posted on the same issue - especially regarding the power input/battery pack issues mentioned by others above.
Perhaps WiiM could consider a compromise, by reducing the power output of the amplifier vis a vis the overall power requirement / battery drain of a potential rechargeable version of the speaker.....
I mean, does it really have to be a wopping 100w peak power output?
50w might be adequate ?
The old Squeezebox Radio is an example of a battery powered streamer albeit from 2010 or so 🙂
I got really excited when the sound was introduced, then again when the sound lite was. But EVERY time these things need AC power, why???? Why can‘t they have a batterypack or at least USB power? It‘s such a majot shame always needing to be close to an outlet :( Why does WiiM make it so hard to have 1 decent system with additional lightet units for multiroom
Audio Pro C3...
Audio Pro C3...
Actually there is no W (Wiim Edition) of the Pro C3 - which is a little bit frustrating.
The only battery powered speaker seems to be the A15W by AudioPro that will be fully compatible within the Wiim ecosystem.
My old C3 seems to integrate well with my four WiiMs but you are correct, its not perfect and I’m considering removing it from my WiiM system in an effort to make the WiiM Home app more stable - suffering many spontaneous crashes at the moment..
I think that’s a big assumption tbh - audio pro wouldn’t claim that and WiiM might try to play nice but it’s not guaranteed
So, sorry this may be a very basic, even dumb question, but just to be completely sure: If I have a WiiM amp connected to a pair of passive speakers + a Subwoofer, if I add a W sound or Sound lite to create a 3.1 setup, will the Sound or Sound lite simultaneously play any source like hdmi, RCA, optical as well as streaming? or will it only work with streaming?
Yes, when I press play on my CD player, my WiiM Amp Ultra automatically detects it, and it is also coming through my sound speaker at the same time. I am playing my CD through optical.
nah, still too expensive....i want something like ikea symfonisk price wise...i am running 2 of them and they are working great...looking for possible replacement, but at 540 euros for 2, i don't think so...it has its advantages, but for a price you can build some small system instead...
some wiim mini+fosi amp+small bookshelf speakers, and you still have money left...
Yes, the price of the Lite here was a big disappointment for me as well at AUD$399. For less than half that ($160), I purchased a WiiM Mini and an Echo 4th Gen during the Prime sales and have pretty much the same result. :)
Tech Specs​
Can I get the Sound Lite device, then purchase a remote to use with it? This is for a bedroom, so I don't want a device with a display on it. Thanks!
The remotes seem to be fully exachangable/ compatible. I am using the remote of my Ultra on a Sound that of the Sound on the Ultra.
All three remotes should work the same with the WiiM Sound Lite (and other WiiM devices):
  • WiiM Voice Remote
  • WiiM Voice Remote 2
  • WiiM Voice Remote 2 Lite
It's just that the Voice Remote 2 Lite (which comes with the Sound, but not with the Sound Lite ;)) isn't available as a separate purchase. At least not yet.
Apologies if this has been asked somewhere else. If I have a WiiM Ultra connected to my TV via hdmi arc, can I then group two Sound Lite's with the Ultra to play stereo sound to the Sound Lite's (one set as L, the other as R) from the TV and control volume from the TV remote?
Yes, when I group the Amp Ultra connected to my Google TV with the WiiM Sound and WiiM Sound Lite, I can adjust the group volume using the TV remote.
Since sound also comes out of the speakers connected to the Ultra, I think it's necessary to ensure the amplifier (or DAC) doesn't turn on. Mute is not an option.
