Introducing WiiM Sound Lite: Hi-Res Audio in a Minimalist Design
📢Expanding the WiiM family! WiiM Sound Lite, our newest smart speaker, is here! The WiiM Sound Lite delivers studio-grade sound, seamless connectivity, and whole-home expandability in a sleek, display-free design.
Along with the newly launched WiiM Sound, we've created Sound Lite for music lovers who want powerful, room-filling Hi-Res audio without a touchscreen display. With 24-bit/192 kHz playback, AI RoomFit™ room correction, and versatile EQ customization, this minimalist speaker adapts to any space and any listening preference.
Why WiiM Sound Lite?​
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Presets and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with advanced EQ tools including 10-band graphic and parametric EQ for precise adjustments.
  • AI RoomFit™: Actively takes precise acoustic measurements of your room, crafting customized corrections for optimized audio.
  • Stereo pairing: Seamlessly pair two WiiM Sound Lite speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Google Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, Alexa Cast, or Roon (certification in process).
Powerful, Flexible, and Customizable Sound​
Whether placed on a shelf, counter, nightstand, or wall-mounted, WiiM Sound Lite seamlessly blends into any space while filling it with studio-quality audio.
✅ 100W peak power delivered through a 4" long-throw woofer and dual 1" silk-dome tweeters
✅ Automatic room correction for personalized acoustics
✅ Stereo pairing - connect two for a true left/right speaker setup
✅ Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
Hi-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Google Cast, Alexa Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA
🎤 Control with Alexa or Google Assistant (via compatible devices). WiiM Voice Remote 2 Lite available separately for one-press control.
Smart Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including 10-band graphic & parametric EQ and input-specific adjustments.
🎭 Home Theater ready, use WiiM Sound Lite as surround or center speakers in a Dolby 5.1 setup with compatible WiiM devices.
🖼 Minimalist, display-free design with a clean, modern look that fits effortlessly into any room.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs​
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LC3) | Ethernet | 3.5mm Aux
Sound Performance: 50 Hz - 20 kHz, 100W peak output
Streaming Platforms: Google Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, LMS, Roon Ready
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7" x 5.7" x 7.5" (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound Lite launches December 25th, 2025 on Amazon (US) in white and black for £229 / $229 / AU$399 / €269. Full details at www.wiimhome.com.
Note: The WiiM Voice Remote 2 Lite is not bundled but is fully compatible for users who prefer one-press or push-to-talk control.
Yes, when I group the Amp Ultra connected to my Google TV with the WiiM Sound and WiiM Sound Lite, I can adjust the group volume using the TV remote.
Since sound also comes out of the speakers connected to the Ultra, I think it's necessary to ensure the amplifier (or DAC) doesn't turn on. Mute is not an option.
Thanks very much!
No issues with lipsync?
@cmcc, @Burnside,
5.1 Group's stereo playback with WiiM Sound has an audio delay of approximately 150ms. Setting the group delay to 150ms for stable playback results in lip sync like this.
(The sound you hear is from the WiiM Sound in the next room.)
View attachment 2111.mp4
To my ears, the delay is barely noticeable, but it's obviously unsuitable for gaming.
(If you have a Fire TV Stick, you can adjust the lip sync.)
@cmcc, @Burnside,
Cheers 👍
Another problem pre gain on aux in ,if I turn it up because input little quit,only my left channel volume goes up instead of both in stereo pair
Unfortunately the Stereo Paring is immature but there is hope.
I just got this from WiiM, regarding the missing persistence of stereo grouping.
"The Stereo Group feature will be launching soon—please stay tuned for updates."
Good to hear,hope it’s soon
I saw some mockups of what's planned a little while ago both for stereo pairing and for surround sound setups. I think they'll be pretty great. Once it's all live, we'll keep on listening to feedback and will make adjustments and improvements based on what you all say.
Great to hear,one more thing audio very quite from my tv through aux,I know I can use gain but only turns up 1 speaker from aux in stereo pair,I also know there is a workaround using group and setting WiFi gain on my right speaker but when I use music through my WiFi right channel is to high now so no good,I’m using wiim sound for left and wiim sound light for right as stereo pair,hope this can be fixed soon only got so much time to send them back,but love the sound of them,hoping to keep them if they work as they should,thanks for you feedback.
Turn up the volume on the headphone output of your TV to max.
And please, do use punctuation. It‘s so hard to read and understand.🙏
Hi,volume all the way up on headphone output,never had any problems with any other device
Actually I got that wrong. The volume on the Sound needs to be at 100%. The volume output of the TV is the variable part.
Some TVs also have an output gain. My Panasonics do.
