castalla
Does the Ultra display metadata changes for Internet radio stations, eg. NDR 1? Using a mini via upnp only the initial metadata image is shown & never updates. (all this using the WHA interface.).
Anybody got an answer?Does the Ultra display metadata changes for Internet radio stations, eg. NDR 1? Using a mini via upnp only the initial metadata image is shown & never updates. (all this using the WHA interface.).
3.5”Ah-ha... My Pro shows the metadata changes (squeezelite mode) - so I guess the Ultra will do the same.
So now, just what are the Ultra screen dimensions (h x w)?
On my ultra no artwork is shown but the text changes, much like the app, when playing thru vtuner. Where do you play it from on LMS?Does the Ultra display metadata changes for Internet radio stations, eg. NDR 1? Using a mini via upnp only the initial metadata image is shown & never updates. (all this using the WHA interface.).
RNP mainly via ARD Videothek.On my ultra no artwork is shown but the text changes, much like the app, when playing thru vtuner. Where do you play it from on LMS?
I’m being thick tonight clearly - can’t see it under RNP or elsewhere in LMS…RNP mainly via ARD Videothek.
Also works via Tunein (cos I'm non-uk)
I think you also need the ARD Videothek pluginI’m being thick tonight clearly - can’t see it under RNP or elsewhere in LMS…
Slowly getting there…I think you also need the ARD Videothek plugin
Yes, ARD needed.I think you also need the ARD Videothek plugin
Thanks for the confirmation. Thinking about adding an Ultra... not really needed but....Finally got it running and the artwork shows on the Ultra as it does in the app. However, there’s a bug in my iPad app which means my artwork isn’t displayed there while the Ultra’s is.
